Both sides previous revision Previous revision | |||
lcrc:introduction [2023/04/27 19:18] asc [Using Singularity for cvmfsexec] |
lcrc:introduction [2023/06/15 14:05] rwang [Using interactive jobs] |
Line 172: | Line 172: | ||
You should be able to do for example: | You should be able to do for example: | ||
- | <codde> | + | <code> |
-ssh bebop | -ssh bebop | ||
-screen | -screen | ||
Line 196: | Line 196: | ||
+ | ====== CVMFS repositories ====== | ||
+ | Mounted CVMFS repositories on Bebop and Swing computing node. | ||
+ | Note, they are not mounted on login nodes | ||
====== Using Singularity ====== | ====== Using Singularity ====== | ||
