In order to use HEP/LCRC computing resources, you will need an account for the ATLAS-g group. Look at the page: https://accounts.lcrc.anl.gov/ You will need to ask to join to the “ATLAS-HEP-group” by providing your ANL user name. The users are usually placed into the “g-ATLAS” group.
Please also look at the description https://collab.cels.anl.gov/display/HEPATLASLCRC
The description here uses the bash shell. Please go to https://accounts.lcrc.anl.gov/account.php to change your shell.
At this very moment (Jan 2018), this resource cannot replace the ATLAS cluster and have several features:
The following interactive nodes can be used:
heplogin.lcrc.anl.gov # login at random to either hepd-0003 or hepd-0004 heplogin1.lcrc.anl.gov # login directly to hepd-0003 heplogin2.lcrc.anl.gov # login directly to hepd-0004
Each node has 72 CPUs and a lot of memory. After login, you will end up in a rather small “home” space which has a limit of 500 GB.
/home/[USER]
You can use this location to keep code etc. (but not data):
/lcrc/group/ATLAS/users/[USER]
LCRC is not user friendly system when it comes to login and passwords. Changing passwords is a “process”. If you went through all steps in changing your ANL domain password, you will need to create ssh public key, update it on your account https://accounts.lcrc.anl.gov/account.php, and then send email to [email protected] with the request to update public key in your account. Since it involves manual labor from the LCRC, do not expect that you will be able to login to the LCRC at the same day.
Read:
You can setup some pre-defined HEP software as:
source /soft/hep/hep_setup.sh
It will set gcc7.1, root, FastJet, Pythia8, LHAPDF etc. Look at the directory “/soft/hep/”. Note sets ROOT 6.12 with all plugins included. PyROOT uses Python 2.7 compiled under gcc71.
If you need to setup new TexLive 2016, use:
source /soft/hep/hep_texlive.sh
You can setup more software packages using Lmod. Look at https://www.lcrc.anl.gov/for-users/software/.
You can setup ATLAS software as:
source /soft/hep/setupATLAS
or if you need RUCIO and the grid, use:
source /soft/hep/setupATLASg
In this case you need to put the grid certificate as described in Grid certificate.
Significant data from the grid should be put to the following locations:
/lcrc/project/ATLAS/data/ # for the group /lcrc/group/ATLAS/atlasfs/local/[USER] # for users
If you need to run a job interactively, you can allocate a node to do this. Try this command:
srun --pty -p bdwall -A condo -t 24:00:00 /bin/bash
It will allocate a new node (in bash) for 24h. It uses Xeon(R) CPU E5-2695 v4 @ 2.10GHz (36 CPUs per node). More info about this can be found in Running jobs on BeBob. Note that you should keep the terminal open while jobs are running.
When you use bdwall partition, your jobs will accounted against default CPU allocations (100k per 4 months). Therefore, when possible, please use “hepd” partition. See the next section.
srun --pty -p hepd -t 24:00:00 /bin/bash module load StdEnv # important to avoid slum bug
Then you can setup root etc as “source /soft/hep/setup.sh”.
SLURM is used as the batch system. It does whole node scheduling (not “core scheduling”)! If you run single core job, your allocation will be multiplied by 36 (cores!) Please see this page for details on how to use SLURM on LCRC http://www.lcrc.anl.gov/for-users/using-lcrc/running-jobs/running-jobs-on-bebop/
The partion for the HEP nodes is hepd
To run on non HEP nodes use partition bdwall with Account - ATLAS-HEP-group
First, allocate a HEP node:
salloc -N 1 -p hepd -A condo -t 00:30:00
This allocates it for 30 min, but you can allocate it up to 7 days. You cam also allocate it on bebob:
salloc -N 1 -p bdwall --account=ATLAS-HEP-group -t 00:30:00
This does not login you! Check what node did you allocate
squeue -u user
Now you know the node. Then login to bebob (first!) and then ssh to this node.
Another method is to use
srun --pty -p bdwall --account=ATLAS-HEP-group -t 00:30:00 /bin/bash
See more description in: https://www.lcrc.anl.gov/for-users/using-lcrc/running-jobs/running-jobs-on-bebop/
You should be able to do for example:
-ssh bebop -screen -salloc -N 1 -p hepd -A condo -t 96:00:00 -ssh <nodename> -Work on interactive job for x amount of time... -Disconnect from screen (different than exit, see the documentation) -Logout
-Login to the same login node screen was started on -screen -ls -Connect to screen session -Continue where you left off (if they allocation is still active)
See below for more details:
https://www.gnu.org/software/screen/
https://www.hamvocke.com/blog/a-quick-and-easy-guide-to-tmux/
Mounted CVMFS repositories on Bebop and Swing computing node.
/cvmfs/atlas.cern.ch /cvmfs/atlas-condb.cern.ch /cvmfs/grid.cern.ch /cvmfs/oasis.opensciencegrid.org /cvmfs/sft.cern.ch /cvmfs/geant4.cern.ch /cvmfs/spt.opensciencegrid.org /cvmfs/dune.opensciencegrid.org /cvmfs/larsoft.opensciencegrid.org /cvmfs/config-osg.opensciencegrid.org /cvmfs/fermilab.opensciencegrid.org /cvmfs/icarus.opensciencegrid.org /cvmfs/sbn.opensciencegrid.org /cvmfs/sw.hsf.org
Note, they are not mounted on login nodes
To run jobs on all LCRC resources using ATLAS analysis base requires Docker/Singularity. Yiming (Ablet) Abulaiti created a tutorial on how to do this. Read this
Here are the suggested steps for 21.2.51 release.
docker pull atlas/analysisbase:21.2.51
Then make singularity image:
docker run -v /var/run/docker.sock:/var/run/docker.sock -v `pwd`:/output --privileged -t --rm singularityware/docker2singularity:v2.3 atlas/analysisbase:21.2.51
Currently, the image for AtlasBase 2.2.51 located here:
/soft/hep/atlas.cern.ch/repo/containers/images/singularity/atlas_analysisbase_21.2.51-2018-11-04-01795eabe66c.img
You can go inside this image as:
singularity exec /soft/hep/atlas.cern.ch/repo/containers/images/singularity/atlas_analysisbase_21.2.51-2018-11-04-01795eabe66c.img bash -l
One can also setup cvmf on any LCRC nodes as this:
source /soft/hep/CVMFSexec/setup.sh
Then check:
ls /cvmfs/
You will see the mounted directory (SL7):
atlas-condb.cern.ch/ atlas.cern.ch/ cvmfs-config.cern.ch/ sft-nightlies.cern.ch/ sw.hsf.org/ atlas-nightlies.cern.ch/ cms.cern.ch/ projects.cern.ch/ sft.cern.ch/ unpacked.cern.ch/
— Sergei&Doug&Rui 2018/01/04 13:36
