Differences
fcs:fccee:tutorial [2023/05/24 13:22] hepsim17 [Data streaming] |
fcs:fccee:tutorial [2023/05/24 13:25] hepsim17 [Data streaming] |
Line 215: | Line 215: | ||
One can also analyze truth-level files using data streaming, i.e. without downloading the actual input files. | One can also analyze truth-level files using data streaming, i.e. without downloading the actual input files. | ||
+ | This example shows data for Higgs to bbar at 240 GeV e+e-. | ||
Click the code shown below, save it as " | Click the code shown below, save it as " | ||
Line 327: | Line 328: | ||
+ | If you run this code as Jython script inside Jas4pp, you will see a histogram updated in real time: | ||
===== Preparation for fast simulation ===== | ===== Preparation for fast simulation ===== |
