Differences
hepsim:jas4pp [2021/02/14 03:14] hepsim17 [Reading ROOT files] |
hepsim:jas4pp [2021/02/17 00:11] hepsim17 |
Line 41: | Line 41: | ||
* Downloading and searching HepSim data | * Downloading and searching HepSim data | ||
* Processing ProMC files from HepSim | * Processing ProMC files from HepSim | ||
+ | * Processing ROOT files created by the Delphes program for fast simulation | ||
* Running over SLCIO files with Geant4 simulated / reconstructed events. | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
* Data analysis (jets, physics vectors, histogram packages) | * Data analysis (jets, physics vectors, histogram packages) | ||
- | * Visualisation | + | * Visualization |
- | You can find more details in [[https:// | + | You can find more details in [[https:// |
Line 198: | Line 199: | ||
- | Jas4pp natively reads ROOT files including files created using ROOT (versions 3, 4, 5 and 6 are supported). | + | Jas4pp natively reads commonly used objects and data structures from [[https:// |
- | One can find some examples in the directory " | + | ROOT files can be loaded using the Jas4pp menu [File]-[Open data source]-[Root file] (*.root). |
- | Here is a Jython/ | + | In addition, one can work with ROOT files using Python/ |
+ | One can find some examples in the directory " | ||
<hidden Show example of a Python code here> | <hidden Show example of a Python code here> |
