Differences
hepsim:quick [2021/05/07 18:29] hepsim17 [Quick start] |
hepsim:quick [2023/03/02 18:28] hepsim17 |
Line 27: | Line 27: | ||
Use [[https:// | Use [[https:// | ||
(*.lcio) files with Geant4 simulations. | (*.lcio) files with Geant4 simulations. | ||
- | This program can also be used for truth-level records in the [[https:// | + | This program can also be used for truth-level records in the [[https:// |
====== Finding data files ====== | ====== Finding data files ====== | ||
Let us show how to find the files associated with a given Monte Carlo event sample. | Let us show how to find the files associated with a given Monte Carlo event sample. | ||
Go to [[https:// | Go to [[https:// | ||
It shows URL of truth-level files (" | It shows URL of truth-level files (" | ||
You can use the command line tool to list files associated with a dataset as: | You can use the command line tool to list files associated with a dataset as: | ||
Line 65: | Line 63: | ||
where [name] is the name of dataset. You can also use a URL if you want to create a list of files from certain (mirror) servers. | where [name] is the name of dataset. You can also use a URL if you want to create a list of files from certain (mirror) servers. | ||
====== Searching for datasets ====== | ====== Searching for datasets ====== | ||
The best method to find the needed sample is to use the web page with | The best method to find the needed sample is to use the web page with | ||
Line 74: | Line 72: | ||
see samples with fast simulations. If you search for " | see samples with fast simulations. If you search for " | ||
for Higgs. Also you can use complex searches, such as " | for Higgs. Also you can use complex searches, such as " | ||
You can also use convenient URL links that search for some datasets. Here are a few examples: | You can also use convenient URL links that search for some datasets. Here are a few examples: | ||
* [[https:// | * [[https:// |
