Differences
hepsim:jas4pp [2017/02/07 02:56] hepsim17 [Programming with HepSim] |
hepsim:jas4pp [2021/02/17 16:15] (current) hepsim17 [Reading ROOT files] |
Line 6: | Line 6: | ||
- | [[http:// | + | [[https:// |
a data-analysis environment for detector and physics studies of future circular colliders. | a data-analysis environment for detector and physics studies of future circular colliders. | ||
- | Jas4PP is a merge of several open-source Java projects, such as [[http:// | + | Jas4PP is a merge of several open-source Java projects, such as [[http:// |
The installation does not have external dependencies besides Java. Make sure that Oracle Java8 and above is installed (not OpenJDK). | The installation does not have external dependencies besides Java. Make sure that Oracle Java8 and above is installed (not OpenJDK). | ||
- | You can download the Jas4pp program using the [[http:// | + | You can download the Jas4pp program using the [[https:// |
Then run these commands to install the package using Linux/Mac with the " | Then run these commands to install the package using Linux/Mac with the " | ||
- | wget http:// | + | wget https:// |
tar -zvxf jas4pp.tgz | tar -zvxf jas4pp.tgz | ||
cd jas4pp | cd jas4pp | ||
Line 41: | Line 41: | ||
* Downloading and searching HepSim data | * Downloading and searching HepSim data | ||
* Processing ProMC files from HepSim | * Processing ProMC files from HepSim | ||
+ | * Processing ROOT files created by the Delphes program for fast simulation | ||
* Running over SLCIO files with Geant4 simulated / reconstructed events. | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
* Data analysis (jets, physics vectors, histogram packages) | * Data analysis (jets, physics vectors, histogram packages) | ||
- | * Visualisation | + | * Visualization |
- | You can find more details in [[http:// | + | |
+ | You can find more details in [[https:// | ||
+ | <note tip>Note that you can also use the [[hepsim: | ||
+ | Jas4pp</ | ||
====== Examples ====== | ====== Examples ====== | ||
Line 59: | Line 61: | ||
fpad examples/ | fpad examples/ | ||
- | The last example from the [[http:// | + | The last example from the [[https:// |
You can also run these examples as " | You can also run these examples as " | ||
Line 110: | Line 112: | ||
====== Reading LCIO files ====== | ====== Reading LCIO files ====== | ||
Line 192: | Line 195: | ||
Also, look at concrete example of how to analyze single particles in [[: | Also, look at concrete example of how to analyze single particles in [[: | ||
+ | Jas4pp natively reads commonly used objects and data structures from [[https:// | ||
+ | ROOT files can be loaded using the Jas4pp menu [File]-[Open data source]-[Root file] (*.root). | ||
+ | In addition, one can work with ROOT files using Python/ | ||
+ | One can find some examples in the directory " | ||
+ | <hidden Show example of a Python code here> | ||
+ | <code python> | ||
+ | from hep.io.root.interfaces import TTree | ||
+ | from hep.io.root import RootFileReader | ||
+ | reader = RootFileReader(" | ||
+ | tree = reader.get(" | ||
+ | maxevents=tree.getEntries() | ||
+ | leaves = tree.getLeaves() | ||
+ | nrleaves=leaves.size() | ||
+ | print "Nr of events=", | ||
+ | print "Nr of leaves=", | ||
+ | print " | ||
+ | for l in xrange( nrleaves ): | ||
+ | print " | ||
+ | print "Run over events" | ||
+ | f0=leaves.get(0); | ||
+ | f1=leaves.get(1); | ||
+ | f2=leaves.get(2); | ||
+ | for i in xrange(tree.getEntries()): | ||
+ | print f0.getValue(i), | ||
+ | The example directory also shows how to read histograms. | ||
+ | Similar examples can be made using Java or Groovy scripting. | ||
+ | The supported ROOT interfaces are: | ||
+ | <hidden show more details on ROOT interfaces here> | ||
+ | TArrayC | ||
+ | TArrayD | ||
+ | TArrayF | ||
+ | TArrayI | ||
+ | TArray | ||
+ | TArrayL | ||
+ | TAttAxis | ||
+ | TAttFill | ||
+ | TAttLine | ||
+ | TAttMarker | ||
+ | TAxis | ||
+ | TBasket | ||
+ | TBranchClones | ||
+ | TBranchElement | ||
+ | TBranch | ||
+ | TBranchObject | ||
+ | TClonesArray | ||
+ | TCollection | ||
+ | TDatime | ||
+ | TDirectory | ||
+ | TFile | ||
+ | TGraph | ||
+ | TH1D | ||
+ | TH1F | ||
+ | TH1 | ||
+ | TH2D | ||
+ | TH2F | ||
+ | TH2 | ||
+ | TKey | ||
+ | TLeafB | ||
+ | TLeafC | ||
+ | TLeafD | ||
+ | TLeafElement | ||
+ | TLeafF | ||
+ | TLeafI | ||
+ | TLeaf | ||
+ | TLeafL | ||
+ | TLeafObject | ||
+ | TLeafO | ||
+ | TLeafS | ||
+ | TList | ||
+ | TMap | ||
+ | TNamed | ||
+ | TObjArray | ||
+ | TObject | ||
+ | TProfile | ||
+ | TSeqCollection | ||
+ | TStreamerBase | ||
+ | TStreamerBasicPointer | ||
+ | TStreamerBasicType | ||
+ | TStreamerElement | ||
+ | TStreamerInfo | ||
+ | TStreamerLoop | ||
+ | TStreamerObjectAny | ||
+ | TStreamerObject | ||
+ | TStreamerObjectPointer | ||
+ | TStreamerString | ||
+ | TString | ||
+ | TTree | ||
+ | One can browser histogram (or ROOT objects) using this: | ||
+ | import rootio | ||
+ | rootio.HBrowser(" | ||
+ | rootio.Browser(" | ||
+ | You will see the browsers: | ||
+ | The script that call these browsers | ||
+ | To read ROOT files from Delphes simulations, | ||
+ | [[https:// | ||
+ | getFloat, getDouble, getInt, and getBool. But first, explore the Delphes ROOT file using the browser shown above. | ||
+ | Here is an example that uses high-level classes to read transverse momentum (PT) and pseudorapidity (ETA) of Monte Carlo particles: | ||
+ | <hidden Click here to show a Python code to read Delphes files> | ||
+ | from rootio import * | ||
+ | branches=tree.getBranches() | ||
+ | print "Nr of branches=", | ||
+ | print " | ||
+ | for l in xrange( branches.size() | ||
+ | print " | ||
+ | particles=tree.getBranch(" | ||
+ | ptEvents=Delphes.getFloat(particles," | ||
+ | etaEvents=Delphes.getFloat(particles," | ||
+ | from jhplot import * | ||
+ | h1 = H1D(" | ||
+ | h2 = H1D(" | ||
+ | for j in xrange(len(pt)): | ||
+ | c=HPlot(" | ||
+ | c.visible() | ||
+ | c.setAutoRange() | ||
+ | c.draw(h1) | ||
+ | c.cd(2,1) | ||
+ | c.draw(h2) | ||
+ | <note warning> | ||
+ | ====== Using GUI mode ====== | ||
+ | You can also run Jas4pp in a GUI mode. You can process scripts that read PROMC and LCIO files from these HepSim pages: | ||
+ | - [[https:// | ||
+ | Download any of these scripts, and open it using the " | ||
====== Programming with HepSim ====== | ====== Programming with HepSim ====== | ||
Line 212: | Line 404: | ||
Here are a few most common classes: | Here are a few most common classes: | ||
- | * [[http://jwork.org/dmelt/ | + | * [[https://datamelt.org/ |
The main canvas to show histograms [[http:// | The main canvas to show histograms [[http:// | ||
- | In addition, data are saved in the form of XML (with the extension " | + | In addition, data are saved in the form of XML (with the extension " |
===== Lorentz particles and Jets ===== | ===== Lorentz particles and Jets ===== | ||
- | * [[http://jwork.org/dmlt/ | + | * [[https://datamelt.org/ |
Line 235: | Line 427: | ||
- | You can build the standard kt-jets using [[http://jwork.org/dmelt/ | + | You can build the standard kt-jets using [[http://datamelt.org/ |
- | [[http://jwork.org/dmelt/ | + | [[https://datamelt.org/ |
- | + | ====== Visualizing | |
- | ====== Visualizing | + | |
You can run Jas+Wired to visualize the simulated events. | You can run Jas+Wired to visualize the simulated events. | ||
Line 251: | Line 438: | ||
This will start a Jas3-like environment | This will start a Jas3-like environment | ||
- | Then copy the detector geometry file from the [[http:// | + | Then copy the detector geometry file from the [[https:// |
This will create a directory " | This will create a directory " | ||
Line 271: | Line 458: | ||
Now press [Go] again to look at next event. | Now press [Go] again to look at next event. | ||
- | + | If you want to see how data records are organized inside the slcio file, | |
- | If you want to see how data records are organized inside the slcio file, | + | |
do this **[File]-[New]-[LCSim Event browser]** | do this **[File]-[New]-[LCSim Event browser]** | ||
- | Generally, when you open a SLCIO file from the HepSim, you do not need to load the geometry file. The geometry file will be downloaded automatically from HepSim and will be put to " | + | |
+ | Here is an example of how to visualize LCIO files from the [[http:// | ||
+ | <code bash> | ||
+ | wget https:// | ||
+ | ./jaspp pgun_muon1024gev_001_pandora.slcio | ||
+ | Click " | ||
+ | Then go to the next event, click "Go next" in the menu. This image illustrates a single electron event: | ||
+ | Similarly, you can view any events form the HepSim directory. The LCIO event file automatically installs | ||
+ | the required detector geometry, i.e. | ||
Line 311: | Line 512: | ||
* S.Chekanov (ANL, main developer) | * S.Chekanov (ANL, main developer) | ||
* E.May (ANL, debugging, Wired4) | * E.May (ANL, debugging, Wired4) | ||
+ | * Gagik Gavalian (JLab) | ||
Line 318: | Line 520: | ||
- | * [[http://jwork.org/dmelt]] - DMelt | + | * [[http://datamelt.org]] - DataMelt |
* [[https:// | * [[https:// | ||
