asc:jas4pp:hepsim [2016/04/05 22:05] asc |
asc:jas4pp:hepsim [2016/04/05 22:07] asc [HepSim Analysis Primer] |
Line 14: | Line 14: | ||
The example codes on this page can be run using several options: | The example codes on this page can be run using several options: | ||
- | * Using Java web start from the browser from the HepSim database info pages | + | * Java web start from the browser from the HepSim database info pages |
- | * Using " | + | * The light-weight |
- | * Using [[http:// | + | * [[http:// |
