asc:jas4pp
Differences
asc:jas4pp [2021/02/16 23:37] – [Analysis of Delphes ROOT files] asc | asc:jas4pp [2021/08/06 12:57] – [People] asc | ||
Line 27: | Line 27: | ||
a data-analysis environment for detector and physics studies of future circular colliders. Jas4PP is a merge of several open-source Java projects, such as | a data-analysis environment for detector and physics studies of future circular colliders. Jas4PP is a merge of several open-source Java projects, such as | ||
- | * Many file formats used in HEP, including | + | * Many file formats used in HEP, including |
- | * [[https:// | + | * [[https:// |
* [[https:// | * [[https:// | ||
Line 62: | Line 62: | ||
bash> jaspp | bash> jaspp | ||
- | The last command starts Jas4PP GUI. | + | The last command starts Jas4PP GUI: |
+ | Use this GUI to explore examples with data visualisation shown in the main window: | ||
+ | [JAS4PP examples]-[Python examples] and then [F2] (or use the mouse menu) to execute: | ||
If you run Jython/ | If you run Jython/ | ||
Line 303: | Line 312: | ||
- | The script that calls these browsers | + | The last image shows the complete class structure of the ROOT file. |
+ | Thses scripts | ||
Line 315: | Line 325: | ||
This functionality is unchanged compared to [[http:// | This functionality is unchanged compared to [[http:// | ||
===== Analysis of Delphes ROOT files ===== | ===== Analysis of Delphes ROOT files ===== | ||
Line 332: | Line 341: | ||
rootio.Browser(" | rootio.Browser(" | ||
+ | The browser | ||
The process the tree " | The process the tree " | ||
Here is a simple code to show a histogram with particle ID: | Here is a simple code to show a histogram with particle ID: | ||
<hidden Click here to show a Python code to read Delphes files> | <hidden Click here to show a Python code to read Delphes files> | ||
<code python> | <code python> | ||
Line 348: | Line 357: | ||
reader = RootFileReader(xf) | reader = RootFileReader(xf) | ||
tree = reader.get(" | tree = reader.get(" | ||
- | maxevents=tree.getEntries() | ||
branches=tree.getBranches() | branches=tree.getBranches() | ||
print "Nr of events=", | print "Nr of events=", | ||
Line 369: | Line 376: | ||
print PID.getName(), | print PID.getName(), | ||
- | ### plot particle ID ## | ||
from jhplot import * | from jhplot import * | ||
- | h1 = H1D(" | + | h1 = H1D(" |
pid=leaves.get(0) # get values with PID for all events | pid=leaves.get(0) # get values with PID for all events | ||
Line 385: | Line 391: | ||
- | Note this code only works for integer values. If you need to extract double, float or boolean, use the Java class "Delphes". | + | Note this code only works for integer values |
- | Here is an example that use high-level classes to read PT and ETA of particles: | + | |
+ | If you need to extract double, float or boolean | ||
+ | getFloat, getDouble, getInt, and getBool. | ||
+ | Here is an example that uses high-level classes to read transverse momentum (PT) and pseudorapidity (ETA) of Monte Carlo particles: | ||
Line 394: | Line 403: | ||
from rootio import * | from rootio import * | ||
- | xf=" | + | reader |
- | + | tree = reader.get(" | |
- | # examine file before doing anything | + | |
- | # import rootio | + | |
- | # rootio.Browser(xf) | + | |
- | reader = RootFileReader(xf) | + | |
- | tree = reader.get(" | + | |
- | maxevents=tree.getEntries() | + | |
print "Nr of branches=", | print "Nr of branches=", | ||
print " | print " | ||
- | for l in xrange( branches.size() | + | for l in xrange( branches.size() ): |
- | particles=tree.getBranch(" | + | particles=tree.getBranch(" |
ptEvents=Delphes.getFloat(particles," | ptEvents=Delphes.getFloat(particles," | ||
etaEvents=Delphes.getFloat(particles," | etaEvents=Delphes.getFloat(particles," | ||
Line 438: | Line 439: | ||
<note warning> | <note warning> | ||
+ | Jas4pp can visualize histograms created by Fortran or C++ code (but without using ROOT). For this, use a light stand-alone library called CFBook (See [[https:// | ||
+ | <hidden Click to show the Python code> | ||
+ | <code python> | ||
+ | from jhplot | ||
+ | from jhplot.io import * | ||
+ | hb = CFBook() | ||
+ | hb.read(" | ||
+ | print hb.listAll() | ||
+ | print hb.getKeysH1D() # list keys | ||
+ | h1=hb.getH1D(1) | ||
+ | c1=HPlot(" | ||
+ | c1.setGTitle(" | ||
+ | c1.visible(1) | ||
+ | c1.setAutoRange() | ||
+ | c1.draw(h1) | ||
====== Reading LCIO files ====== | ====== Reading LCIO files ====== | ||
Line 771: | Line 794: | ||
* N.Nikiforou | * N.Nikiforou | ||
* G.Gavalian (JLab) | * G.Gavalian (JLab) | ||
+ | * Khushi Taori (ANL SULI 2021 student). ROOT6 support | ||
asc/jas4pp.txt · Last modified: 2024/01/30 15:50 by asc
