Both sides previous revision Previous revision | Next revision Both sides next revision | ||
asc:jas4pp [2023/05/24 01:59] asc |
asc:jas4pp [2023/05/24 02:00] asc |
Line 48: | Line 48: | ||
- | <note tip>Although Jas4pp works on JDK8, we strongly recommend to use JDK9 (or OpenJDK9) and above. This will significantly increase the speed for numeric computations. | + | <note tip>We strongly recommend to use JDK18 (or OpenJDK18) and above. This will significantly increase the speed for numeric computations. |
