asc:promc:examples [2014/10/14 01:44] asc [ProMC Examples] |
asc:promc:examples [2015/03/20 01:13] asc |
Line 6: | Line 6: | ||
(written by S.Chekanov, ANL) | (written by S.Chekanov, ANL) | ||
- | ProMC binary | + | ProMC files are compact and self-describing |
to ProMC files. More information is in the [[asc: | to ProMC files. More information is in the [[asc: | ||
Line 33: | Line 33: | ||
Look at the Python examples discussed bellow how to use a random access via the network. | Look at the Python examples discussed bellow how to use a random access via the network. | ||
+ | Note that the browser can open ProMC files of any size, since it loads only a fraction of data. This is especially useful compared to limitations | ||
+ | of some formats that cannot be viewed in text editors if their sizes are too large. | ||
Line 55: | Line 58: | ||
After the installation, | After the installation, | ||
$PROMC/ | $PROMC/ | ||
- | Take a look at them. Each director has "Makefile" | + | If you already know that your file include information from a typical parton-shower Monte Carlo model, |
+ | <code bash> | ||
+ | $PROMC/ | ||
+ | that reads a ProMC file. The makefile links "libpromc.a" | ||
+ | If you know that stored data are from a NLO program, looks at: | ||
+ | $PROMC/examples/ | ||
+ | that links the " | ||
- | ProMC files are self-describing. You can generate | + | ProMC files are self-describing, therefore you can read and write any type of data and generate static libraries from platform-neutral templates. |
+ | You can generate | ||
if you happen to have a ProMC file but do not know how the data are organized inside the file. You need to install [[asc: | if you happen to have a ProMC file but do not know how the data are organized inside the file. You need to install [[asc: | ||
Line 196: | Line 212: | ||
The example given in the directory " | The example given in the directory " | ||
- | ===== Benchmark summary | ||
- | Here is a comparison of file sizes for the same event records written by " | ||
- | ^ File format | ||
- | | ASCII TXT file (" | ||
- | | ROOT tree (Double32_t) | ||
- | As one can see, the ProMC files are 40% more compact than the equivalent ROOT files and 23% more compact than gzipped ASCII TXT (" | ||
Line 240: | Line 242: | ||
- | An example program which fills ProMC file record is given here | + | An example program which fills ProMC file record is given in |
- | [[http://atlaswww.hep.anl.gov/asc/WebSVN/ | + | [[https://github.com/Argonne-National-Laboratory/ProMC/blob/master/examples/pythia/|Pythia8 to ProMC example]] |
Line 462: | Line 464: | ||
- | - [[http://atlaswww.hep.anl.gov/asc/WebSVN/filedetails.php? | + | - [[https://github.com/Argonne-National-Laboratory/ProMC/ |
- [[http:// | - [[http:// | ||
