asc:promc:installation [2015/01/15 21:56] asc [Installation from the source (Linux)] |
asc:promc:installation [2015/01/15 22:24] asc [Installation from the source (Mac OS)] |
Line 108: | Line 108: | ||
====== Installation from the source (Mac OS) ====== | ====== Installation from the source (Mac OS) ====== | ||
- | For MacOS (Darwin), first install these libraries: pkgconfig, wget, gcc etc. You can can use Xcode and Fink and to install such dev libraries. | + | For MacOS (Darwin), first install these libraries: pkgconfig, wget, gcc. You can can use Xcode and Fink and to install such dev libraries. |
If you do not use " | If you do not use " | ||
Line 118: | Line 118: | ||
+ | bash | ||
tar -zvxf ProMC.tgz | tar -zvxf ProMC.tgz | ||
cd ProMC | cd ProMC | ||
source [promc_dir]/ | source [promc_dir]/ | ||
- | To test the installation, | + | To test the installation, |
Line 135: | Line 136: | ||
- | You can download compiled ProMC library (MacOS 10.10.1) from [[http:// | + | You can download |
Thanks to Larry Nodulman for verifying this installation. | Thanks to Larry Nodulman for verifying this installation. | ||
Line 196: | Line 196: | ||
- | ===== Installation | + | ===== Installation |
