asc:promc [2014/10/14 19:51] asc |
asc:promc [2016/03/29 17:18] asc [References:] |
Line 11: | Line 11: | ||
- **[[asc: | - **[[asc: | ||
- | - **[[https:// | + | - **[[https:// |
//Monte Carlo event repositories based on ProMC:// | //Monte Carlo event repositories based on ProMC:// | ||
- | - [[http:// | + | |
- | | + | * [[http:// |
Line 23: | Line 24: | ||
* S.Chekanov, "Next generation input-output data format for HEP using Google' | * S.Chekanov, "Next generation input-output data format for HEP using Google' | ||
* S.Chekanov, E.May, K. Strand, P. Van Gemmeren, ProMC: Input-output data format for HEP applications using varint encoding, ANL-HEP-PR-13-41, | * S.Chekanov, E.May, K. Strand, P. Van Gemmeren, ProMC: Input-output data format for HEP applications using varint encoding, ANL-HEP-PR-13-41, | ||
+ | ====== Talks: ====== | ||
+ | S.V.Chekanov. {{: | ||
