asc:tutorials:2014october [2014/10/29 15:30] asc [Lesson 5: Running a job on multiple cores] |
asc:tutorials:2014october [2014/10/29 20:31] asc [Lesson 6: Working on the ANL farm] |
Line 272: | Line 272: | ||
- | source setup.sh | ||
mkdir lesson_3; cd lesson_3 | mkdir lesson_3; cd lesson_3 | ||
+ | source setup.sh | ||
rcSetup -u; rcSetup Base,2.0.12 | rcSetup -u; rcSetup Base,2.0.12 | ||
rc find_packages | rc find_packages | ||
Line 326: | Line 326: | ||
+ | <note tip>If the program fails saying that some shared library has a wrong format, clean ROOTCORE as "rc clean", | ||
====== Lesson 4: Filling histograms ====== | ====== Lesson 4: Filling histograms ====== | ||
Line 333: | Line 334: | ||
mkdir lesson_4; cd lesson_4 | mkdir lesson_4; cd lesson_4 | ||
+ | Then setup atlas environment: | ||
Line 451: | Line 454: | ||
- | Now run " | + | Now let us |
+ | <code bash> | ||
+ | ./A_RUN | ||
You can monitor jobs with this command (launched in a separate terminal): | You can monitor jobs with this command (launched in a separate terminal): | ||
Line 465: | Line 472: | ||
- | If it does not work: Debug it as: | + | If it does not work: debug it as: |
testRun 00 | testRun 00 | ||
+ | The command runs one job using the input list inputs/ | ||
+ | (Typically, this is due to wrong location of the goodrunlist) | ||
+ | If you run this program second time, clean the output directory: | ||
+ | rm -rf outputs/* | ||
+ | (ROOTCORE does not like existing output directories) | ||
- | This will process inputs/ | ||
- | (Typically, this is due to wrong location of the goodrunlist). | ||
**Attention: | **Attention: | ||
Line 528: | Line 543: | ||
- | When the jobs are done, the output files will be inside "Jobs" directory. Merge the ROOT outputs into one file as: | + | When the jobs are done, the output files will be inside |
Line 556: | Line 571: | ||
See the instruction on how | See the instruction on how | ||
+ | ======Using Eclipse to develop ATLAS code====== | ||
+ | [[asc: | ||
