asc:tutorials:2014october28
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
asc:tutorials:2014october28 [2014/10/28 20:35] – [Lesson 1: Looking at a xAOD file] asc | asc:tutorials:2014october28 [2014/10/29 13:53] – old revision restored (2014/10/28 16:33) asc | ||
Line 293: | Line 293: | ||
python Make_input < | python Make_input < | ||
+ | In case if you need xAOD data, do this: | ||
+ | <code bash> | ||
+ | mkdir data | ||
+ | cd data | ||
+ | localSetupFAX --rootVersion=current-SL6 | ||
+ | voms-proxy-init -voms atlas | ||
+ | xrdcp $STORAGEPREFIX/ | ||
+ | and run: | ||
+ | cd .. | ||
+ | python Make_input data | ||
+ | Now inputdata.txt should pick up your xAOD files. | ||
Now the input file is ready and we run the example as: | Now the input file is ready and we run the example as: | ||
Line 311: | Line 333: | ||
To do this we will need a number of changes: | To do this we will need a number of changes: | ||
- | 1) We need to link several ATLAS packages. | + | 1) We need to link several ATLAS packages |
Line 319: | Line 341: | ||
in " | in " | ||
- | 2) Then we need to modify 2 places to put histograms | + | 2) Then we need to modify 2 places to put histograms |
<code python> | <code python> | ||
Line 371: | Line 393: | ||
TBrowser a | TBrowser a | ||
- | and look at the histograms | + | and look at the histograms |
asc/tutorials/2014october28.txt · Last modified: 2014/10/29 13:55 by asc
