asc:tutorials:2014october28
Differences
asc:tutorials:2014october28 [2014/10/28 20:42] – [Lesson 3: C++/ROOT program to read xAOD] asc | asc:tutorials:2014october28 [2014/10/28 21:33] – [Lesson 4: Filling histograms] asc | ||
Line 296: | Line 296: | ||
In case if you need xAOD data, do this: | In case if you need xAOD data, do this: | ||
mkdir data | mkdir data | ||
cd data | cd data | ||
localSetupFAX --rootVersion=current-SL6 | localSetupFAX --rootVersion=current-SL6 | ||
voms-proxy-init -voms atlas | voms-proxy-init -voms atlas | ||
- | xrdcp $STORAGEPREFIX/ | + | xrdcp $STORAGEPREFIX/ |
Line 312: | Line 312: | ||
python Make_input data | python Make_input data | ||
+ | Now inputdata.txt should pick up your xAOD files. | ||
Line 333: | Line 333: | ||
To do this we will need a number of changes: | To do this we will need a number of changes: | ||
- | 1) We need to link several ATLAS packages. | + | 1) We need to link several ATLAS packages |
Line 341: | Line 341: | ||
in " | in " | ||
- | 2) Then we need to modify 2 places to put histograms | + | 2) Then we need to modify 2 places to put histograms |
<code python> | <code python> | ||
Line 393: | Line 393: | ||
TBrowser a | TBrowser a | ||
- | and look at the histograms | + | and look at the histograms |
asc/tutorials/2014october28.txt · Last modified: 2014/10/29 13:55 by asc
