User Tools
Site Tools
asc:tutorials:eclipse
Differences
Link to this comparison view
Next revision
Previous revision
asc:tutorials:eclipse [2014/10/29 14:57]
aparamonov
asc:tutorials:eclipse [2014/10/29 21:20]
asc
Line 1: Line 1:
 ====== Eclipse ====== ====== Eclipse ======
Line 10: Line 12:
   - Extract folder "eclipse" to a location where you want to store the executable.  E.G. C:\Program Files\   - Extract folder "eclipse" to a location where you want to store the executable.  E.G. C:\Program Files\
   - Enter the folder and execute "eclipse". It will ask you for location of the workspace. That's where the source code is stored.   - Enter the folder and execute "eclipse". It will ask you for location of the workspace. That's where the source code is stored.
 +<note tip>For ANL, eclipse is installed in /share/sl6/eclipse/ directory.</note>
 ===== Install SVN plugins ===== ===== Install SVN plugins =====
Line 35: Line 39:
 ===== Import a package from SVN ===== ===== Import a package from SVN =====
   - Return to "C/C++ Perspective": click the icon in the upper-right corner of the window.   - Return to "C/C++ Perspective": click the icon in the upper-right corner of the window.
Line 47: Line 50:
   - Now the syntax checking, indexing, and autocomplete are enabled.   - Now the syntax checking, indexing, and autocomplete are enabled.
 +===== Edit the code  =====
 +  - Press Shift+Ctrl+F
 +  - It will auto-alight the code.
 +  - Go to line 128 and type "jets_" and press "Ctrl+Space". The auto-coplete will finish the name.
 +  - Delete "jets_shallowCopy" and enter ";" instead.
 +  - Let's commit that into the SVN repository.
 +  - Right-click on SUSYToolsAlg.cxx and select "Team -> Commit...".
 +  - Select "Yes." Enter your comment and click "OK".
 +  - Ops.. we do not have permissions to do that.
 +  - Well, that is how you synchronize your code with a repository.
 +  - Right-click on SUSYToolsAlg.cxx and select "Team -> Revert". The file is returned to the original state.
 +===== Add libraries  =====
 +  - You may want to keep your code aware of external libraries (e.g. ROOT).
asc/tutorials/eclipse.txt ยท Last modified: 2014/10/29 21:20 by asc
