asc:workbook_cpf [2013/10/22 16:20] asc |
asc:workbook_cpf [2013/10/22 16:22] asc |
Line 12: | Line 12: | ||
cd example/arc | cd example/arc | ||
====== Checking available data ====== | ====== Checking available data ====== | ||
Line 20: | Line 17: | ||
It is good idea to check the availability of your data in the ArCond static database. As example, you can list all files on all boxes as: | It is good idea to check the availability of your data in the ArCond static database. As example, you can list all files on all boxes as: | ||
- | Data are arranged on several disks (/data1, /data2, /data3, /data4, /data5, / | + | < |
+ | All data are arranged on several disks (/data1, /data2, /data3, /data4, /data5, / | ||
You can check all data available on a specific disk ("/ | You can check all data available on a specific disk ("/ | ||
Line 38: | Line 36: | ||
If you are looking for a specific MC, pipe the output to " | If you are looking for a specific MC, pipe the output to " | ||
arc_ls | arc_ls | ||
(here we are looking for the MC set " | (here we are looking for the MC set " | ||
Line 45: | Line 45: | ||
This is especially useful if you want to check which runs are available. | This is especially useful if you want to check which runs are available. |
