asc:workbook_grid
Differences
Next revision | Previous revisionNext revisionBoth sides next revision | ||
asc:workbook_grid [2013/05/30 18:53] – external edit 127.0.0.1 | asc:workbook_grid [2014/11/25 23:16] – asc | ||
Line 16: | Line 16: | ||
<code bash setup.sh> | <code bash setup.sh> | ||
#!/bin/bash | #!/bin/bash | ||
- | export | + | export |
- | export TEST_AREA=$HOME/testarea | + | |
export ATLAS_LOCAL_ROOT_BASE=/ | export ATLAS_LOCAL_ROOT_BASE=/ | ||
source ${ATLAS_LOCAL_ROOT_BASE}/ | source ${ATLAS_LOCAL_ROOT_BASE}/ | ||
- | asetup | + | localSetupDQ2Client |
+ | voms-proxy-init -voms atlas -valid 96:00 | ||
Put it in a file " | Put it in a file " | ||
- | Then type: | ||
- | localSetupDQ2Client | ||
- | voms-proxy-init -voms atlas -valid 96:00 | ||
Say " | Say " | ||
Line 43: | Line 37: | ||
- | Before starting using this, type: | ||
- | voms-proxy-init -voms atlas | ||
- | or using the standard (proxy for 3 days): | + | In this example, we use |
grid-proxy-init -valid | grid-proxy-init -valid | ||
Line 58: | Line 48: | ||
voms-proxy-info -all | voms-proxy-info -all | ||
+ | If there is a problem run these commands to debug them: | ||
+ | setupATLAS | ||
+ | diagnostics | ||
+ | gridCert | ||
Then check the location of your data: | Then check the location of your data: | ||
Line 73: | Line 72: | ||
- | ====== Using Pathena | + | ====== Using Pathena commands ====== |
Do the setup as above then then type: | Do the setup as above then then type: | ||
Line 83: | Line 82: | ||
The general ATLAS instructions for pathena can be found [[https:// | The general ATLAS instructions for pathena can be found [[https:// | ||
+ | Also look at: | ||
+ | [[https:// | ||
+ | (attention: do not setup dq2-get together with panda!) | ||
- | ====== Setting up Grid Certificates ====== | + | ===== Putting files on the grid ===== |
+ | (thanks to Taylor for checking) | ||
+ | Setup Atlas release. For SL6, source this code: | ||
- | * Request a DOE grid certificate using this site http://www.doegrids.org/pages/ | + | <code bash> |
- | * Once your request is approved, you'll be sent a link to retrieve your certificate. At the bottom of that page, there is a link to import your certificate | + | #!/bin/bash |
- | * Import your certificate and then you'll want to export | + | export AVERS=17.7.0 |
- | In Fuirefox, just go to " | + | export TEST_AREA=$HOME/testarea |
- | | + | export |
- | + | source ${ATLAS_LOCAL_ROOT_BASE}/ | |
- | The first time you need to use your certificate, | + | asetup |
- | + | localSetupDQ2Client | |
- | < | + | voms-proxy-init -voms atlas -valid 96:00 |
- | openssl pkcs12 | + | localSetupPandaClient |
- | You will be asked several times for the password. Use the same as that when you made backup copy. | + | Then put files (assumes MWT2_UC_SCRATCHDISK): |
- | Then do: | ||
- | chmod 600 $HOME/.globus/userkey.pem | + | dq2-put -d -L MWT2_UC_SCRATCHDISK |
- | chmod 644 $HOME/ | + | |
- | You can test that the certificate is working correctly by typing " | + | Create and register it before doing this: |
- | If you are already a member of ATLAS, then you just need to join the Virtual Organization. The instructions can be found here [[http:// | + | |
- | Follow the instructions on that page exactly. When you get to the set where it redirects you to https:// | + | |
- | You will be a candidate until they approve you and then you'll need to go back to [[https:// | + | |
- | Your grid will work only when you will get the email (usually takes 1-3 days): | + | |
+ | You can also register it on the grid. | ||
- | Dear VO Member, | + | dq2-register-dataset user.< |
- | The membership status has been changed from New to Approved due to the following reason: Approved for your VOMRS atlas account with primary certificate: | + | dq2-register-location user.< |
- | DN: / | + | |
- | CA: / | + | |
- | Please contact VO administrator if you have any questions. | + | |
asc/workbook_grid.txt · Last modified: 2023/10/04 19:04 by asc
