asc:workbook_grid
Differences
asc:workbook_grid [2013/10/23 15:27] – asc | asc:workbook_grid [2014/05/07 15:28] – [Putting files on the grid] asc | ||
Line 73: | Line 73: | ||
- | ====== Using Pathena | + | ====== Using Pathena commands ====== |
Do the setup as above then then type: | Do the setup as above then then type: | ||
Line 83: | Line 83: | ||
The general ATLAS instructions for pathena can be found [[https:// | The general ATLAS instructions for pathena can be found [[https:// | ||
+ | Also look at: | ||
+ | [[https:// | ||
+ | (attention: do not setup dq2-get together with panda!) | ||
+ | ===== Putting files on the grid ===== | ||
+ | (thanks to Taylor for checking) | ||
+ | Setup Atlas release. For SL6, source this code: | ||
+ | <code bash> | ||
+ | #!/bin/bash | ||
+ | export AVERS=17.7.0 | ||
+ | export TEST_AREA=$HOME/ | ||
+ | export ATLAS_LOCAL_ROOT_BASE=/ | ||
+ | source ${ATLAS_LOCAL_ROOT_BASE}/ | ||
+ | asetup --release=$AVERS --cmtconfig=x86_64-slc6-gcc46-opt --testarea=$TEST_AREA | ||
+ | localSetupDQ2Client | ||
+ | voms-proxy-init -voms atlas -valid 96:00 | ||
+ | localSetupPandaClient --noAthenaCheck | ||
+ | Then put files (assumes MWT2_UC_SCRATCHDISK): | ||
+ | dq2-put -d -L MWT2_UC_SCRATCHDISK | ||
+ | You can also register it on the grid. | ||
+ | dq2-register-dataset user.< | ||
+ | dq2-register-location user.< | ||
asc/workbook_grid.txt · Last modified: 2023/10/04 19:04 by asc
