asc:workbook_grid
Differences
asc:workbook_grid [2014/02/11 20:12] – [Using Pathena and pbook, prun commands] asc | asc:workbook_grid [2014/05/07 15:28] – [Putting files on the grid] asc | ||
Line 82: | Line 82: | ||
The general ATLAS instructions for pathena can be found [[https:// | The general ATLAS instructions for pathena can be found [[https:// | ||
+ | Also look at: | ||
+ | [[https:// | ||
+ | (attention: do not setup dq2-get together with panda!) | ||
Line 101: | Line 105: | ||
+ | Then put files (assumes MWT2_UC_SCRATCHDISK): | ||
+ | dq2-put -d -L MWT2_UC_SCRATCHDISK | ||
+ | You can also register it on the grid. | ||
+ | dq2-register-dataset user.< | ||
+ | dq2-register-location user.< | ||
asc/workbook_grid.txt · Last modified: 2023/10/04 19:04 by asc
