asc:workbook_introduction
Differences
asc:workbook_introduction [2014/02/14 16:58] – [Cleaning environmental variables] asc | asc:workbook_introduction [2023/08/14 19:17] – [Default shell and environment] asc | ||
Line 18: | Line 18: | ||
===== Interactive nodes and desktops ===== | ===== Interactive nodes and desktops ===== | ||
- | At ANL ASC one can use any of these " | + | To login to atlas clusters (not LCRC!) |
- | ^ name ^ cores Linux ^ | + | |
- | | atlas15.hep.anl.gov | 8 | + | |
- | | atlas16.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas17.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas18.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas1.hep.anl.gov | + | |
- | | atlas2.hep.anl.gov | + | |
+ | alogin1.hep.anl.gov | ||
+ | alogin2.hep.anl.gov | ||
You should use ANL domain password and user name. All other computers can be accessed from the computers above. It should be noted that they require the ANL domain password and the user name. | You should use ANL domain password and user name. All other computers can be accessed from the computers above. It should be noted that they require the ANL domain password and the user name. | ||
- | Desktop computers do not have login from outside. | ||
===== Data storage ===== | ===== Data storage ===== | ||
Line 39: | Line 34: | ||
- | /atlasfs/atlas/local | + | /data/atlasfs02/ |
- | Please check your name there. | ||
- | In addition, every server has scratch space here: | + | ===== Setting up some software ===== |
- | <code bash> | + | |
- | /data1/ | + | |
- | /data2/ | + | |
- | atlas2 has more space in /data1, /data2, /data3, /data4. | ||
- | Finally, you can use " | + | You can setup some software (ROOT, FASTJET, PYTHIA, new Latex) as this: |
- | The computer farm has distributed data storage managed by [[http:// | ||
- | ===== Computer farm ===== | ||
+ | <code bash> | ||
+ | source / | ||
+ | This setup uses the native Python2 from SL7 | ||
- | The computer farm consists of 16 servers atlas50-65. Each server has 2 CPU with 8 cores and 5 TB of local disk space. | ||
- | The PC farm uses the [[http:// | ||
- | simplifies the data discovery. The backend | ||
- | as long as you restrict your jobs to atlas50-65 and use 4 cores per server. If you have long jobs, please use the old farm. Login to the computer farm is not allowed. | ||
- | You can see the current CPU usage using this web page [[http:// | ||
- | You can run [[http:// | + | You can also setup basic programs using Python3. Create a setup file "setup.sh" as this: |
- | /share/grid/app/asc_app/ | + | #!/bin/bash |
- | cp -rf /share/sl6/ | + | echo "Setup ROOT, PyROOT tensorflow" |
- | cd jcondor | + | export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase |
- | java -jar jcondor.jar | + | source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh |
+ | lsetup "views LCG_104 x86_64-centos7-gcc11-opt" | ||
- | ===== After initial login ===== | ||
+ | Then you can setup many LCG packages as: | ||
- | About the scratch disk space: It is available on atlas1, | + | < |
- | + | source setup.sh | |
- | In some cases, you will need to access data from all computers. If data size is not large (not larger than 10 GB), one can put data on NFS: /data/ | + | </code> |
Please read the section [[asc: | Please read the section [[asc: | ||
- | ===== Default shell and environment ===== | ||
- | The default shell for the ANL ASC is bash. | ||
- | To setup the necessary environment (ROOT, SVN etc), run this script: | ||
- | <code bash source.sh> | ||
- | source / | ||
Check this by running " | Check this by running " | ||
Line 98: | Line 76: | ||
alias ls='ls -F --color=auto' | alias ls='ls -F --color=auto' | ||
- | source / | ||
Line 108: | Line 85: | ||
echo $FASTJET | echo $FASTJET | ||
echo $LHAPDF | echo $LHAPDF | ||
+ | echo $PROMC | ||
Line 116: | Line 94: | ||
- | Before compiling any package, please check this directory. | + | Before compiling any package, please check this directory. Note that you can also use cvmfs " |
- | Note that you can use cvmfs " | + | |
Line 125: | Line 101: | ||
localSetupSFT --help | localSetupSFT --help | ||
- | This prints available (non-ATLAS) software. | + | This prints |
===== Setting up ATLAS Software ===== | ===== Setting up ATLAS Software ===== | ||
- | To setup ATLAS software | + | To setup ATLAS software, copy and save these lines in a file, say " |
<code bash setup.sh> | <code bash setup.sh> | ||
Line 162: | Line 138: | ||
and run the script " | and run the script " | ||
+ | Read more [[https:// | ||
===== COOL database ===== | ===== COOL database ===== |
asc/workbook_introduction.txt · Last modified: 2023/08/14 19:20 by asc
