asc:workbook_introduction
Differences
asc:workbook_introduction [2014/07/11 21:29] – asc | asc:workbook_introduction [2023/08/14 19:16] – [Setting up some software] asc | ||
Line 18: | Line 18: | ||
===== Interactive nodes and desktops ===== | ===== Interactive nodes and desktops ===== | ||
- | At ANL ASC one can use any of these " | + | To login to atlas clusters (not LCRC!) |
- | ^ name ^ cores Linux ^ | + | |
- | | atlas15.hep.anl.gov | 8 | + | |
- | | atlas16.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas17.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas18.hep.anl.gov | 16 SL6.4 | Public login for ALL ASC users | | + | |
- | | atlas1.hep.anl.gov | + | |
- | | atlas2.hep.anl.gov | + | |
+ | alogin1.hep.anl.gov | ||
+ | alogin2.hep.anl.gov | ||
You should use ANL domain password and user name. All other computers can be accessed from the computers above. It should be noted that they require the ANL domain password and the user name. | You should use ANL domain password and user name. All other computers can be accessed from the computers above. It should be noted that they require the ANL domain password and the user name. | ||
- | Desktop computers do not have login from outside. | ||
===== Data storage ===== | ===== Data storage ===== | ||
Line 39: | Line 34: | ||
- | /atlasfs/atlas/local | + | /data/atlasfs02/ |
- | Please check your name there. In addition, every server has scratch space here: | ||
- | <code bash> | ||
- | /data1/ | ||
- | /data2/ | ||
- | atlas2 has more space in /data1, /data2, /data3, /data4. | + | ===== Setting up some software ===== |
- | Finally, you can use " | ||
- | The computer farm has distributed data storage managed by [[http:// | ||
- | ===== Computer farm ===== | ||
+ | You can setup some software (ROOT, FASTJET, PYTHIA, new Latex) as this: | ||
- | The computer farm consists of 16 servers atlas50-65. Each server has 2 CPU with 8 cores and 5 TB of local disk space. | ||
- | The PC farm uses the [[http://atlaswww.hep.anl.gov/asc/arcond/|Arcond]] for job submission which allows to share the resources and | + | <code bash> |
- | simplifies | + | source |
- | as long as you restrict your jobs to atlas50-65 and use 4 cores per server. If you have long jobs, please use the old farm. Login to the computer farm is not allowed. | + | </ |
+ | This setup uses the native Python2 from SL7 | ||
- | You can see the current CPU usage using this web page [[http:// | ||
- | You can run [[http:// | + | You can also setup basic programs using Python3. Create a setup file "setup.sh" as this: |
- | /share/sl6/set_asc.sh | + | #!/bin/bash |
- | cp -rf /share/sl6/jcondor | + | echo "Setup ROOT, PyROOT tensorflow" |
- | cd jcondor | + | export ATLAS_LOCAL_ROOT_BASE=/ |
- | java -jar jcondor.jar | + | source ${ATLAS_LOCAL_ROOT_BASE}/ |
+ | lsetup "views LCG_104 x86_64-centos7-gcc11-opt" | ||
- | ===== After initial login ===== | + | Then you can setup many LCG packages as: |
+ | source setup.sh | ||
+ | Please read the section [[asc: | ||
- | About the scratch disk space: It is available on atlas1, | ||
- | In some cases, you will need to access data from all computers. If data size is not large (not larger than 10 GB), one can put data on NFS: / | ||
- | Please read the section [[asc: | ||
asc/workbook_introduction.txt · Last modified: 2023/08/14 19:20 by asc
