asc:workbook_introduction [2023/08/14 19:12] asc [Data storage] |
asc:workbook_introduction [2023/08/14 19:19] asc [Setting up some software] |
Line 38: | Line 38: | ||
- | ===== Computer farm ===== | + | ===== Setting up some software |
- | The computer farm consists of 16 servers atlas50-65. Each server has 2 CPU with 8 cores and 5 TB of local disk space. | + | You can setup some software (ROOT, FASTJET, PYTHIA, new Latex) as this: |
- | The PC farm uses the [[http:// | ||
- | simplifies the data discovery. The backend | ||
- | as long as you restrict your jobs to atlas50-65 and use 4 cores per server. If you have long jobs, please use the old farm. Login to the computer farm is not allowed. | ||
- | You can see the current CPU usage using this web page [[http:// | ||
- | You can run [[http:// | ||
- | /share/sl6/ | + | source |
- | cp -rf /share/sl6/jcondor . | + | |
- | cd jcondor | + | |
- | java -jar jcondor.jar | + | |
- | ===== After initial login ===== | + | |
- | About the scratch disk space: It is available on atlas1, | + | |
- | In some cases, you will need to access data from all computers. If data size is not large (not larger than 10 GB), one can put data on NFS: / | + | |
- | Please read the section [[asc: | + | |
- | ===== Default shell and environment ===== | + | |
- | The default shell for the ANL ASC is bash. | + | |
- | To setup the necessary environment (ROOT, SVN etc), run this script: | + | |
- | <code bash source.sh> | + | |
- | source / | + | |
+ | This setup uses the native Python2 from SL7 | ||
Check this by running " | Check this by running " | ||
Line 82: | Line 53: | ||
alias ls='ls -F --color=auto' | alias ls='ls -F --color=auto' | ||
- | source / | ||
Line 95: | Line 65: | ||
- | All precompiled software is located here: | ||
+ | == Python3 from LCG == | ||
+ | You can also setup basic programs using Python3. Create a setup file " | ||
- | /share/sl6/ | + | #!/bin/bash |
+ | echo "Setup ROOT, PyROOT tensorflow" | ||
+ | export ATLAS_LOCAL_ROOT_BASE=/cvmfs/ | ||
+ | source ${ATLAS_LOCAL_ROOT_BASE}/ | ||
+ | lsetup "views LCG_104 x86_64-centos7-gcc11-opt" | ||
+ | Then you can setup many LCG packages as: | ||
+ | source setup.sh | ||
+ | Please read the section [[asc: | ||
Before compiling any package, please check this directory. Note that you can also use cvmfs " | Before compiling any package, please check this directory. Note that you can also use cvmfs " |
