Both sides previous revision Previous revision | Last revision Both sides next revision | ||
asc:workbook_introduction [2023/08/14 19:17] asc [Default shell and environment] |
asc:workbook_introduction [2023/08/14 19:19] asc [Setting up some software] |
Line 49: | Line 49: | ||
This setup uses the native Python2 from SL7 | This setup uses the native Python2 from SL7 | ||
+ | Check this by running " | ||
+ | <code bash> | ||
+ | alias ls='ls -F --color=auto' | ||
+ | This will set up the recent version of ROOT with the native PYTHON 2.4 from SL5.3. Alternatively, | ||
+ | At this point, no any atlas software is installed. Note that the same setup script also setup FASTJET and LHAPDF. Check this as | ||
+ | echo $FASTJET | ||
+ | echo $LHAPDF | ||
+ | echo $PROMC | ||
+ | == Python3 from LCG == | ||
You can also setup basic programs using Python3. Create a setup file " | You can also setup basic programs using Python3. Create a setup file " | ||
Line 68: | Line 85: | ||
Please read the section [[asc: | Please read the section [[asc: | ||
- | Check this by running " | ||
- | <code bash> | ||
- | alias ls='ls -F --color=auto' | ||
- | This will set up the recent version of ROOT with the native PYTHON 2.4 from SL5.3. Alternatively, | ||
- | At this point, no any atlas software is installed. Note that the same setup script also setup FASTJET and LHAPDF. Check this as | ||
- | echo $FASTJET | ||
- | echo $LHAPDF | ||
- | echo $PROMC | ||
- | All precompiled software is located here: | ||
- | /share/sl6/ | ||
Before compiling any package, please check this directory. Note that you can also use cvmfs " | Before compiling any package, please check this directory. Note that you can also use cvmfs " |
