community:hepsim:dev_fast [2016/04/28 18:21] asc [Creating Delphes files] |
community:hepsim:dev_fast [2016/04/28 18:22] asc [Creating fast detector simulations] |
Line 1: | Line 1: | ||
- | ====== Creating fast detector simulations ====== | + | |
===== Creating Delphes files ===== | ===== Creating Delphes files ===== | ||
Line 46: | Line 46: | ||
===== On the fly reconstruction ===== | ===== On the fly reconstruction ===== | ||
- | HepSim | + | HepSim |
- | one can analyse events after the Delphes fast simulation program on the fly. | + | |
The latter approach allows to make changes to the detector geometry by the end-users and, at the the same time, perform an analysis. | The latter approach allows to make changes to the detector geometry by the end-users and, at the the same time, perform an analysis. | ||
The output ROOT file only includes histograms defined by the user (but you can also add custom ROOT tree). | The output ROOT file only includes histograms defined by the user (but you can also add custom ROOT tree). |
