community:hepsim:dev_hepsim [2016/10/28 09:22] asc |
community:hepsim:dev_hepsim [2016/12/22 15:52] asc |
Line 3: | Line 3: | ||
====== How to link private samples to HepSim ====== | ====== How to link private samples to HepSim ====== | ||
- | Your files can be published on HepSim and you can maintain your own Hepim repository with PROMC/ | + | Your files can be published on [[http:// |
* You want to share your own files, so they will be available from HepSim | * You want to share your own files, so they will be available from HepSim | ||
- | | + | * You want to make a |
- | If the dataset is new, you will see a new entry in the HepSim database. | ||
- | If you have made a mirror, your server will be added as a mirror for a given dataset. | ||
- | Your authorship will be preserved | + | If the dataset is new, you will see a new entry in the HepSim database. |
+ | If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset. | ||
====== What do you need ====== | ====== What do you need ====== | ||
Line 18: | Line 17: | ||
You need the following: | You need the following: | ||
- | * A web server that can hold your data (>1 TB is recommended) | + | * A web server that can hold your data (>1 TB for / |
* Linux OS (any flavor) | * Linux OS (any flavor) | ||
- | * Installed | + | * Apache2 with PHP module |
+ | * Java 8 JDK or JRE (optionally, | ||
- | The root directory of a typical HepSim repository | + | The root directory of a typical HepSim repository |
- | be served by Apache. You will need to make the directory structure such as: | + | be served by Apache, i.e. it should be visible from / |
Line 77: | Line 77: | ||
You can mirror an entire dataset by copying HepSim files to your mirror web server (or local computer). | You can mirror an entire dataset by copying HepSim files to your mirror web server (or local computer). | ||
- | You can use this {{: | + | You can use the command "hs-mirror" from the "hs-toolkit" |
to mirror a dataset with known URL, use this example: | to mirror a dataset with known URL, use this example: | ||
+ | wget http:// | ||
+ | source hs-toolkit/ | ||
+ | # now copy a dataset from URL to a new location | ||
SOURCE=http:// | SOURCE=http:// | ||
OUTPUT_DIR=/ | OUTPUT_DIR=/ | ||
- | hs-mirror.py -i $SOURCE-o $OUTPUT_DIR | + | hs-mirror -i $SOURCE-o $OUTPUT_DIR |
- | This example | + | This example |
URL. The URL can be found using the HepSim web page. | URL. The URL can be found using the HepSim web page. | ||
+ | If you want to download only EVGEN files, without reconstructed events, use this command: | ||
+ | <code bash> | ||
+ | hs-mirror -i $SOURCE-o $OUTPUT_DIR -t evgen | ||
Generally, you do not need to index files in the mirror directory. | Generally, you do not need to index files in the mirror directory. | ||
====== Summary ====== | ====== Summary ====== | ||
When everything is done, this is what you will expect: | When everything is done, this is what you will expect: | ||
- | * You files will be visible on the main HepSim web page and on the mirrors (takes ~ few days to propagate the changes) | + | * You files will be visible on the main HepSim web page and on the current |
- | * You can search your files etc. | + | * You can search your files etc. using the main HepSim web page |
- | * Since your files are public, there is good chance that somebody will make a mirror | + | |
* You can search, list and download files using hs-toolkit commands (hs-find, hs-ls, hs-get etc) | * You can search, list and download files using hs-toolkit commands (hs-find, hs-ls, hs-get etc) | ||
+ | * Since your files are public, there is good chance that somebody will make a mirror to reduce the load on your server | ||
* You server will be listed on the page [[http:// | * You server will be listed on the page [[http:// | ||
