community:hepsim:dev_opentasks [2016/05/24 15:01] asc |
community:hepsim:dev_opentasks [2016/05/25 15:15] asc |
Line 1: | Line 1: | ||
+ | [[community: | ||
====== Open tasks ====== | ====== Open tasks ====== | ||
There is a number of technical tasks that are ideal for scientists who would like to contribute to | There is a number of technical tasks that are ideal for scientists who would like to contribute to | ||
open-source particle simulations and outreach. | open-source particle simulations and outreach. | ||
- | Your work will be fully acknowleged | + | HepSim projects can expand your programming |
- | Such tasks are especially useful | + | data analysis. HepSim uses the same general software and tools as for the ongoing and future experiments. The only difference |
+ | is that HepSim packages | ||
+ | to worry about permissions from HEP experiments/ | ||
- | | + | Here are several open tasks: |
- | detector designs and Monte Carlo simulations and can expand your skills in programming . Here is the list: | + | |
+ | * Improve the converter " | ||
+ | * The FCC-hh detector has about 300 overlaps in the inner/outer tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT. | ||
+ | * Detector and events should be viewed using a Web event browser based on WebGL or other methods. Please look at the [[http:// | ||
+ | * Improvements for the graphics of [[https:// | ||
+ | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
- | * Improve the converter " | + | Of course, you can do a lot of your own research, including physics performance studies using truth-level, |
- | * The FCC-hh detector has about 300 overlaps of the inner tracker (support structures | + | You are only limited by your own imagination. |
- | * Each detector should be viewed using online event browser using WebGL or other methods. Please look at the CMS detector example in [[http:// | + | |
- | * Improvements for the graphics of Jas4pp [[https:// | + | |
+ | Please contact [email protected] if you are interested in these tasks. | ||
- | Please contact me (S.Chekanov) if you are interested in these tasks. | + | --- // |
