community:hepsim:dev_opentasks [2016/05/24 15:09] asc |
community:hepsim:dev_opentasks [2016/05/25 15:15] asc |
Line 1: | Line 1: | ||
+ | [[community: | ||
====== Open tasks ====== | ====== Open tasks ====== | ||
There is a number of technical tasks that are ideal for scientists who would like to contribute to | There is a number of technical tasks that are ideal for scientists who would like to contribute to | ||
open-source particle simulations and outreach. | open-source particle simulations and outreach. | ||
- | HepSim projects can expand your programming | + | HepSim projects can expand your programming |
- | data analysis. HepSim uses the same software and tools as those used in actual | + | data analysis. HepSim uses the same general |
- | is that the software is not proprietorial, | + | is that HepSim packages are not proprietorial, |
- | to ask the permission | + | to worry about permissions from HEP experiments/ |
+ | Here are several open tasks: | ||
- | * Improve the converter " | + | * Improve the converter " |
- | * The FCC-hh detector has about 300 overlaps | + | * The FCC-hh detector has about 300 overlaps |
- | * Each detector | + | * Detector and events |
* Improvements for the graphics of [[https:// | * Improvements for the graphics of [[https:// | ||
+ | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
+ | Of course, you can do a lot of your own research, including physics performance studies using truth-level, | ||
+ | You are only limited by your own imagination. | ||
- | Of course, you can do a lot of your own research - here you are limited by your own imagination. | + | Please contact [email protected] if you are interested in these tasks. |
- | Please contact me (S.Chekanov) if you are interested in these tasks. | + | --- // |
