community:hepsim:dev_opentasks [2016/05/24 15:16] asc |
community:hepsim:dev_opentasks [2016/05/25 15:14] asc |
Line 5: | Line 5: | ||
There is a number of technical tasks that are ideal for scientists who would like to contribute to | There is a number of technical tasks that are ideal for scientists who would like to contribute to | ||
open-source particle simulations and outreach. | open-source particle simulations and outreach. | ||
- | HepSim projects can expand your programming | + | HepSim projects can expand your programming |
- | data analysis. HepSim uses the same software and tools as those used in actual | + | data analysis. HepSim uses the same general |
- | is that the software is not proprietorial, | + | is that HepSim packages are not proprietorial, |
- | to ask the permission | + | to ask permissions from HEP experiments/ |
- | * Improve the converter " | + | Here are several open tasks: |
- | * The FCC-hh detector has about 300 overlaps of the inner tracker (support structures | + | |
- | * Each detector should be viewed using online event browser based on WebGL or other methods. Please look at the CMS detector example in [[http:// | + | |
- | * Improvements for the graphics of [[https:// | + | |
- | * Improvements in HepRApp code. Currently, it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | + | |
+ | * Improve the converter " | ||
+ | * The FCC-hh detector has about 300 overlaps in the inner/outer tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT. | ||
+ | * Detector and events should be viewed using a Web event browser based on WebGL or other methods. Please look at the [[http:// | ||
+ | * Improvements for the graphics of [[https:// | ||
+ | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
Of course, you can do a lot of your own research, including physics performance studies using truth-level, | Of course, you can do a lot of your own research, including physics performance studies using truth-level, | ||
- | You are limited | + | You are only limited by your own imagination. |
- | Please contact | + | Please contact |
