community:hepsim:dev_opentasks [2016/05/24 22:18] asc old revision restored (2016/05/24 17:17) |
community:hepsim:dev_opentasks [2016/05/25 15:14] asc |
Line 12: | Line 12: | ||
Here are several open tasks: | Here are several open tasks: | ||
- | * Improve the converter " | + | * Improve the converter " |
- | * The FCC-hh detector has about 300 overlaps | + | * The FCC-hh detector has about 300 overlaps |
- | * Each detector | + | * Detector and events |
* Improvements for the graphics of [[https:// | * Improvements for the graphics of [[https:// | ||
- | * Improvements in HepRApp code. Currently, it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | + | * Improvements in HepRApp code. Currently, |
Of course, you can do a lot of your own research, including physics performance studies using truth-level, | Of course, you can do a lot of your own research, including physics performance studies using truth-level, |
