community:hepsim:dev_truth [2016/04/28 15:28] asc [Single-particle gun] |
community:hepsim:dev_truth [2016/06/13 13:52] asc [Using converters] |
Line 5: | Line 5: | ||
HepSim is optimized to keep truth-level in the " | HepSim is optimized to keep truth-level in the " | ||
- | ProMC files can be created directly by Pythi8 (the example " | + | |
- | | + | ====== Using Pythia8====== |
+ | ProMC files can be created directly by Pythia8. Look at the example " | ||
+ | please | ||
+ | of Pythia8. If the environmental variable " | ||
+ | ====== Using converters ====== | ||
+ | You can convert files in the format " | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
Line 13: | Line 23: | ||
Look at the [[asc: | Look at the [[asc: | ||
+ | ====== Using Madgraph5====== | ||
+ | To run MG5 with ProMC, please | ||
+ | Then download MG5 package with preconfigured ProMC converter from [[https:// | ||
+ | <code bash> | ||
+ | wget https:// | ||
+ | tar -zvxf package_mg14tev.tgz | ||
+ | Now check that ProMC is correctly installed. You should be able to compile " | ||
+ | cd package/ | ||
+ | make | ||
+ | If successful, then you should see the binary file " | ||
+ | Now let compile and run " | ||
+ | jobs for 14 TeV pp collision. We assume 64bit Scientific Linux 6.5 computer. Setup gcc47. In the case of ATLAS setup, use: | ||
+ | source setup_gcc47.sh | ||
+ | To create multiple number of files in the ProMC format for " | ||
+ | It does the following: It runs the script " | ||
+ | and runs the promc converter. | ||
+ | The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | ||
+ | All MG5 settings for this particular run are in the directory " | ||
+ | To check the output ProMC file, look at the browser: | ||
+ | wget http:// | ||
+ | java -jar browser_promc.jar out/ | ||
+ | where " | ||
+ | You can host these files on your data storage, or send an email to " | ||
====== Single-particle gun ====== | ====== Single-particle gun ====== | ||
Line 35: | Line 92: | ||
One can mix events from a signal ProMC file with | One can mix events from a signal ProMC file with | ||
- | inelastic (minbias) events using a " | + | inelastic (minbias) events using a " |
+ | The next example assumes that either the hs-tools package or Jas4pp is installed. | ||
hs-pileup pN signal.promc minbias.promc output.promc | hs-pileup pN signal.promc minbias.promc output.promc |
