community:hepsim:dev_truth [2016/06/13 13:01] asc [Using Madgraph5] |
community:hepsim:dev_truth [2016/06/13 13:51] asc [Using Pythia8] |
Line 5: | Line 5: | ||
HepSim is optimized to keep truth-level in the " | HepSim is optimized to keep truth-level in the " | ||
- | ProMC files can be created directly by Pythi8 (the example " | + | |
- | | + | ====== Using Pythia8====== |
+ | ProMC files can be created directly by Pythia8. Look at the example " | ||
+ | please | ||
+ | of Pythia8. If the environmental variable " | ||
+ | ====== Using converters ====== | ||
+ | You can convert files in the format " | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
Line 16: | Line 26: | ||
To run MG5 with ProMC, please | To run MG5 with ProMC, please | ||
- | The download MG5 with preconfigured ProMC output | + | Then download MG5 package |
Line 31: | Line 41: | ||
If successful, then you should see the binary file " | If successful, then you should see the binary file " | ||
- | Now let compile " | + | Now let compile |
+ | jobs for 14 TeV pp collision. We assume 64bit Scientific Linux 6.5 computer. Setup gcc47. In the case of ATLAS setup, use: | ||
Line 43: | Line 54: | ||
- | It does the following: It runs the script " | + | It does the following: It runs the script " |
- | in the directory " | + | and runs the promc converter. |
+ | The number of output files are given inside | ||
- | To check the output | + | All MG5 settings for this particular run are in the directory " |
+ | To check the output | ||
Line 54: | Line 69: | ||
where " | where " | ||
+ | You can host these files on your data storage, or send an email to " | ||
====== Single-particle gun ====== | ====== Single-particle gun ====== |
