community:hepsim:dev_truth [2016/06/13 13:19] asc |
community:hepsim:dev_truth [2016/06/13 13:52] asc [Using converters] |
Line 5: | Line 5: | ||
HepSim is optimized to keep truth-level in the " | HepSim is optimized to keep truth-level in the " | ||
- | ProMC files can be created directly by Pythi8 (the example " | + | |
- | | + | ====== Using Pythia8====== |
+ | ProMC files can be created directly by Pythia8. Look at the example " | ||
+ | please | ||
+ | of Pythia8. If the environmental variable " | ||
+ | ====== Using converters ====== | ||
+ | You can convert files in the format " | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
Line 16: | Line 26: | ||
To run MG5 with ProMC, please | To run MG5 with ProMC, please | ||
- | The download MG5 with preconfigured ProMC output | + | Then download MG5 package |
Line 31: | Line 41: | ||
If successful, then you should see the binary file " | If successful, then you should see the binary file " | ||
- | Now let compile " | + | Now let compile |
+ | jobs for 14 TeV pp collision. We assume 64bit Scientific Linux 6.5 computer. Setup gcc47. In the case of ATLAS setup, use: | ||
Line 43: | Line 54: | ||
- | It does the following: It runs the script " | + | It does the following: It runs the script " |
+ | and runs the promc converter. | ||
The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | ||
Line 49: | Line 61: | ||
- | To check the output | + | To check the output |
