community:hepsim:dev_truth [2016/06/13 13:45] asc |
community:hepsim:dev_truth [2016/06/13 13:51] asc [Using Pythia8] |
Line 9: | Line 9: | ||
====== Using Pythia8====== | ====== Using Pythia8====== | ||
- | ProMC files can be created directly by Pythi8 directly. Look at the example " | + | ProMC files can be created directly by Pythia8. Look at the example "examples/main46.ccmain46.cc" inside the Pythi8 distribution. |
- | Please | + | please |
of Pythia8. If the environmental variable " | of Pythia8. If the environmental variable " | ||
Line 41: | Line 41: | ||
If successful, then you should see the binary file " | If successful, then you should see the binary file " | ||
- | Now let compile " | + | Now let compile |
+ | jobs for 14 TeV pp collision. We assume 64bit Scientific Linux 6.5 computer. Setup gcc47. In the case of ATLAS setup, use: | ||
Line 53: | Line 54: | ||
- | It does the following: It runs the script " | + | It does the following: It runs the script " |
+ | and runs the promc converter. | ||
The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | ||
Line 59: | Line 61: | ||
- | To check the output | + | To check the output |
