Both sides previous revision Previous revision | Next revision Both sides next revision | ||
community:hepsim:dev_truth [2016/06/13 13:46] asc [Using Madgraph5] |
community:hepsim:dev_truth [2016/06/13 13:47] asc [Using Madgraph5] |
Line 54: | Line 54: | ||
- | It does the following: It runs the script " | + | It does the following: It runs the script " |
+ | and runs the promc converter. | ||
The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | The number of output files are given inside the script A_RUN_ttbar_jet. You should reduce this number if you want to stop earlier. | ||
Line 60: | Line 61: | ||
- | To check the output | + | To check the output |
<code bash> | <code bash> |
