community:hepsim:dev_truth [2016/06/13 13:47] asc [Using Madgraph5] |
community:hepsim:dev_truth [2016/06/13 13:52] asc [Using converters] |
Line 9: | Line 9: | ||
====== Using Pythia8====== | ====== Using Pythia8====== | ||
- | ProMC files can be created directly by Pythi8 directly. Look at the example " | + | ProMC files can be created directly by Pythia8. Look at the example "examples/main46.ccmain46.cc" inside the Pythi8 distribution. |
- | Please | + | please |
of Pythia8. If the environmental variable " | of Pythia8. If the environmental variable " | ||
====== Using converters ====== | ====== Using converters ====== | ||
- | You can convert files in the format " | + | You can convert files in the format " |
* hepmc2promc | * hepmc2promc |
