community:hepsim:pgun [2016/08/02 19:01] asc |
community:hepsim:pgun [2016/11/03 14:44] asc |
Line 1: | Line 1: | ||
+ | [[community: | ||
====== Creating single particle samples ====== | ====== Creating single particle samples ====== | ||
- | Single particle samples are created using the ProMC Java package. | + | Single particle samples are created using the ProMC Java package. |
+ | Here is an example | ||
+ | You can use [[https://atlaswww.hep.anl.gov/asc/jas4pp/ | ||
+ | <code bash> | ||
+ | wget --no-check-certificate https://atlaswww.hep.anl.gov/ | ||
+ | fpad particle_gun.py # run this script using Jas4pp | ||
+ | This commands creates 1000 single-pion events with random Eta, Phi and momenta. | ||
You can modify this script to change pT, Eta etc. | You can modify this script to change pT, Eta etc. | ||
+ | An example implemented in Jython is also given in [[http:// | ||
