community:hepsim:pgun [2016/11/03 13:43] asc [Creating single particle samples] |
community:hepsim:pgun [2016/11/15 17:48] asc |
Line 1: | Line 1: | ||
- | [[community: | + | [[community: |
====== Creating single particle samples ====== | ====== Creating single particle samples ====== | ||
Line 10: | Line 10: | ||
- | wget https:// | + | wget --no-check-certificate |
fpad particle_gun.py # run this script using Jas4pp | fpad particle_gun.py # run this script using Jas4pp | ||
+ | The last command creates 1000 single-pion events with random Eta, Phi and momenta. | ||
You can modify this script to change pT, Eta etc. | You can modify this script to change pT, Eta etc. | ||
