community:hepsim:usage_detectors
Differences
community:hepsim:usage_detectors [2016/06/09 01:33] – [Full (Geant4) simulations] asc | community:hepsim:usage_detectors [2016/08/27 12:26] – asc | ||
Line 27: | Line 27: | ||
^ Tag name ^ Detector description | ^ Tag name ^ Detector description | ||
- | | rfull001 | + | | rfull001 |
- | | rfull002 | + | | rfull002 |
- | | rfull006 | + | | rfull006 |
- | | rfull007 | + | | rfull007 |
- | | rfull008 | + | | rfull009 |
+ | | rfull010 | ||
The output file format is LCIO. The files can be read as explained [[community: | The output file format is LCIO. The files can be read as explained [[community: | ||
ROOT geometry package, run these commands: | ROOT geometry package, run these commands: |
community/hepsim/usage_detectors.txt · Last modified: 2016/11/07 21:56 by asc
