User Tools
Site Tools
community:hepsim:usage_detectors
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
community:hepsim:usage_detectors [2016/06/09 13:23]
asc
community:hepsim:usage_detectors [2016/09/27 13:14]
asc
Line 19: Line 19:
 ====== Full (Geant4) simulations ====== ====== Full (Geant4) simulations ======
Line 24: Line 25:
 The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|here]]. The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|here]].
 +Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as
 +this
 +<code>
 +http://atlaswww.hep.anl.gov/hepsim/lookup.php?info=[TAG]
 +</code>
 +this will print the detector name. Instead of [TAG], use the detector name to determine the tag.
 +Here are the examples:
 +Find the detector that corresponds to the tag "rfull009":
 +[[http://atlaswww.hep.anl.gov/hepsim/lookup.php?info=rfull009]]
 +Find the tag which corresponds to the detector sifcch8:
 +[[http://atlaswww.hep.anl.gov/hepsim/lookup.php?info=sifcch8]]
 +In Linux, you can retrieve this info as:
 +<code>
 +curl -s http://atlaswww.hep.anl.gov/hepsim/lookup.php?info=rfull009
 +</code>
 +The table below shows the available detectors:
 ^ Tag name    ^  Detector description     ^ Documentation / GEO files ^ Available data ^   View ^ ^ Tag name    ^  Detector description     ^ Documentation / GEO files ^ Available data ^   View ^
-| rfull001    |  Original SiD detector, E(CM)=1 TeV (e+e-) (sidloi3).   [[http://mc.hep.anl.gov/asc/hepsim/events/mumu/10tev/mm10tev_pythia6_zprime10tev_ww/rfull001/info.txt|info]]      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.heprep|sidloi3.heprep]]   [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.gdml.gz|sidloi3.gdml.gz]]         [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull001| find=rfull001]]        | {{:community:hepsim:sid.png?400|SiD}} | +| rfull001    |  Original SiD detector, E(CM)=1 TeV (e+e-) (sidloi3).   [[http://mc.hep.anl.gov/asc/hepsim/events/mumu/10tev/mm10tev_pythia6_zprime10tev_ww/rfull001/info.txt|info]]      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.heprep|sidloi3.heprep]]   [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.gdml.gz|sidloi3.gdml.gz]]         [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull001| find=rfull001]]        | {{:community:hepsim:sid.png?200|SiD}} |
-| rfull002    |  CEPC detector, E(CM)=250 GeV (e+e-) (sidcc1) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull002/info.txt|info]]      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.heprep|sidcc1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.gdml.gz|sidcc1.gdml.gz]],          |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull002| find=rfull002]]        | {{:community:hepsim:sicpec.png?400| CEPC}} | +| rfull002    |  CEPC detector, E(CM)=250 GeV (e+e-) (sidcc1) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull002/info.txt|info]]      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.heprep|sidcc1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.gdml.gz|sidcc1.gdml.gz]],          |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull002| find=rfull002]]        | {{:community:hepsim:sicpec.png?200| CEPC}} |
--   |  SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN)  (sieic1)  (development)      |  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.heprep|sieic1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.gdml.gz|sieic1.gdml.gz]]        |          | {{:community:hepsim:sieic.png?400|EIC}} | +rfull051    |  SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN)  (sieic1)  (development)      |  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.heprep|sieic1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.gdml.gz|sieic1.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull051| find=rfull051]]        | {{:community:hepsim:sieic.png?200|EIC}} |
-| rfull006    |  SiFFC-v4 for FCC-hh (pp, E(CM)=100 TeV)      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.heprep|sifcch4.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.gdml.gz|sifcch4.gdml.gz]]          |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006| find=rfull006]]        | {{:community:hepsim:sifcc.png?400|SiFCC}} | +| rfull006    |  SiFFC-v4 for FCC-hh (pp, E(CM)=100 TeV)      [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.heprep|sifcch4.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.gdml.gz|sifcch4.gdml.gz]]          |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006| find=rfull006]]        | {{:community:hepsim:sifcc.png?200|SiFCC}} |
-| rfull007    |  SiFFC-v5. (pp, 100 TeV)  As SiFCC-v4 but with x4 larger HCAL cells        [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.heprep|sifcch5.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.gdml.gz|sifcch5.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull007| find=rfull007]]        | {{:community:hepsim:sifcc.png?400|SiFCC-v4}} | +| rfull007    |  SiFFC-v5. (pp, 100 TeV)  As SiFCC-v4 but with x4 larger HCAL cells        [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.heprep|sifcch5.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.gdml.gz|sifcch5.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull007| find=rfull007]]        | {{:community:hepsim:sifcc.png?200|SiFCC-v4}} |
-rfull008     SiFFC-v7 (pp, 100 TeV)  As SiFCC-v4 but with improved tracker. June 9, 2016    |  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.heprep|sifcch7.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.gdml.gz|sifcch7.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull008| find=rfull008]]        | {{:community:hepsim:sifcc7.png?400|SiFCC-v7}} |+rfull009     SiFFC-v7 (pp, 100 TeV)  As SiFCC-v4 but with improved tracker (corrected infrastructure support for inner and outer tracker, reduced gaps between silicon modules) and Fast Pandora clusteringAug 17, 2016    |  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.heprep|sifcch7.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.gdml.gz|sifcch7.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull009| find=rfull009]]        | {{:community:hepsim:sifcc7.png?200|SiFCC-v7}} |
 +| rfull010    |  Same as  SiFFC-v7, but HCAL cells are 20x20cm (vs 5x5 cm)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.heprep|sifcch8.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.gdml.gz|sifcch8.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull010| find=rfull010]]        | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} |
 +| rfull011    |  Same as  SiFFC-v7, but fine HCAL cells. HCAL cell size is 2x2cm (vs 5x5 cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.heprep|sifcch9.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch9.gdml.gz|sifcch9.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull011| find=rfull011]]        | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} |
 +| rfull012    |  Same as  SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]]        | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} |
 +| rfull013    |  Same as  SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]]        | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} |
 The output file format is LCIO. The files can be read as explained [[community:hepsim:usage_full|here]]. To view geometries using  The output file format is LCIO. The files can be read as explained [[community:hepsim:usage_full|here]]. To view geometries using
community/hepsim/usage_detectors.txt · Last modified: 2016/11/07 21:56 by asc
