community:hepsim:usage_detectors
Differences
community:hepsim:usage_detectors [2016/06/09 13:25] – asc | community:hepsim:usage_detectors [2016/09/10 21:25] – asc | ||
Line 19: | Line 19: | ||
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== | ||
Full simulations use SLIC software. | Full simulations use SLIC software. | ||
The geometry files with full detector descriptions are [[http:// | The geometry files with full detector descriptions are [[http:// | ||
+ | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | ||
+ | this | ||
+ | http:// | ||
+ | this will print the detector name. Instead of [TAG], use the detector name to determine the tag. | ||
+ | Here are the examples: | ||
+ | Find the detector that corresponds to the tag " | ||
+ | [[http:// | ||
+ | Find the tag which corresponds to the detector sifcch8: | ||
+ | [[http:// | ||
+ | In Linux, you can retrieve this info as: | ||
+ | curl -s http:// | ||
^ Tag name ^ Detector description | ^ Tag name ^ Detector description | ||
- | | rfull001 | + | | rfull001 |
- | | rfull002 | + | | rfull002 |
- | | rfull006 | + | | rfull006 |
- | | rfull007 | + | | rfull007 |
- | | rfull008 | + | | rfull009 |
+ | | rfull010 | ||
+ | | rfull011 | ||
+ | | rfull012 | ||
+ | | rfull013 | ||
The output file format is LCIO. The files can be read as explained [[community: | The output file format is LCIO. The files can be read as explained [[community: |
community/hepsim/usage_detectors.txt · Last modified: 2016/11/07 21:56 by asc
