community:hepsim:usage_detectors
Differences
community:hepsim:usage_detectors [2016/06/15 13:40] – [Full (Geant4) simulations] asc | community:hepsim:usage_detectors [2016/09/10 21:21] – asc | ||
Line 19: | Line 19: | ||
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== | ||
Full simulations use SLIC software. | Full simulations use SLIC software. | ||
The geometry files with full detector descriptions are [[http:// | The geometry files with full detector descriptions are [[http:// | ||
+ | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | ||
+ | this | ||
+ | http:// | ||
+ | this will print the detector name. Instead of [TAG], use the detector name to determine the tag. | ||
+ | Here are the examples: | ||
+ | Find the detector that corresponds to the tag " | ||
+ | [[http:// | ||
+ | Find the tag which corresponds to the detector sifcch8: | ||
+ | [[http:// | ||
Line 32: | Line 50: | ||
| rfull006 | | rfull006 | ||
| rfull007 | | rfull007 | ||
- | | rfull008 | + | | rfull009 |
- | | rfull009 | + | | rfull010 |
+ | | rfull011 | ||
+ | | rfull012 | ||
+ | | rfull013 | ||
The output file format is LCIO. The files can be read as explained [[community: | The output file format is LCIO. The files can be read as explained [[community: |
community/hepsim/usage_detectors.txt · Last modified: 2016/11/07 21:56 by asc
