community:hepsim:usage_detectors [2016/08/27 12:26] asc |
community:hepsim:usage_detectors [2016/09/27 13:14] asc |
Line 19: | Line 19: | ||
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== | ||
Line 24: | Line 25: | ||
The geometry files with full detector descriptions are [[http:// | The geometry files with full detector descriptions are [[http:// | ||
+ | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | ||
+ | this | ||
+ | http:// | ||
+ | this will print the detector name. Instead of [TAG], use the detector name to determine the tag. | ||
+ | Here are the examples: | ||
+ | Find the detector that corresponds to the tag " | ||
+ | [[http:// | ||
+ | Find the tag which corresponds to the detector sifcch8: | ||
+ | [[http:// | ||
+ | In Linux, you can retrieve this info as: | ||
+ | curl -s http:// | ||
+ | The table below shows the available detectors: | ||
^ Tag name ^ Detector description | ^ Tag name ^ Detector description | ||
| rfull001 | | rfull001 | ||
| rfull002 | | rfull002 | ||
- | | - | SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic1) | + | | rfull051 |
| rfull006 | | rfull006 | ||
| rfull007 | | rfull007 | ||
| rfull009 | | rfull009 | ||
- | | rfull010 | + | | rfull010 |
+ | | rfull011 | ||
+ | | rfull012 | ||
+ | | rfull013 | ||
The output file format is LCIO. The files can be read as explained [[community: | The output file format is LCIO. The files can be read as explained [[community: | ||
ROOT geometry package, run these commands: | ROOT geometry package, run these commands: |
