community:hepsim:usage_detectors [2016/08/27 12:35] asc |
community:hepsim:usage_detectors [2016/09/10 21:21] asc |
Line 19: | Line 19: | ||
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== | ||
Full simulations use SLIC software. | Full simulations use SLIC software. | ||
The geometry files with full detector descriptions are [[http:// | The geometry files with full detector descriptions are [[http:// | ||
+ | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | ||
+ | this | ||
+ | http:// | ||
+ | this will print the detector name. Instead of [TAG], use the detector name to determine the tag. | ||
+ | Here are the examples: | ||
+ | Find the detector that corresponds to the tag " | ||
+ | [[http:// | ||
+ | Find the tag which corresponds to the detector sifcch8: | ||
+ | [[http:// | ||
Line 34: | Line 52: | ||
| rfull009 | | rfull009 | ||
| rfull010 | | rfull010 | ||
- | | rfull011 | + | | rfull011 |
- | | rfull012 | + | | rfull012 |
| rfull013 | | rfull013 | ||
