community:hepsim:usage_detectors
Differences
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
community:hepsim:usage_detectors [2016/08/27 12:44] – asc | community:hepsim:usage_detectors [2016/09/10 21:21] – asc | ||
Line 19: | Line 19: | ||
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== | ||
Full simulations use SLIC software. | Full simulations use SLIC software. | ||
The geometry files with full detector descriptions are [[http:// | The geometry files with full detector descriptions are [[http:// | ||
+ | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | ||
+ | this | ||
+ | http:// | ||
+ | this will print the detector name. Instead of [TAG], use the detector name to determine the tag. | ||
+ | Here are the examples: | ||
+ | Find the detector that corresponds to the tag " | ||
+ | [[http:// | ||
+ | Find the tag which corresponds to the detector sifcch8: | ||
+ | [[http:// | ||
community/hepsim/usage_detectors.txt · Last modified: 2016/11/07 21:56 by asc
