community:hepsim:usage_detectors [2016/09/10 21:21] asc |
community:hepsim:usage_detectors [2016/09/10 21:26] asc |
Line 41: | Line 41: | ||
[[http:// | [[http:// | ||
+ | In Linux, you can retrieve this info as: | ||
+ | curl -s http:// | ||
+ | The table below shows the available detectors: | ||
^ Tag name ^ Detector description | ^ Tag name ^ Detector description |
