community:hepsim:usage_detectors [2016/09/10 21:21] asc |
community:hepsim:usage_detectors [2016/09/27 13:14] asc |
Line 41: | Line 41: | ||
[[http:// | [[http:// | ||
+ | In Linux, you can retrieve this info as: | ||
+ | curl -s http:// | ||
+ | The table below shows the available detectors: | ||
^ Tag name ^ Detector description | ^ Tag name ^ Detector description | ||
| rfull001 | | rfull001 | ||
| rfull002 | | rfull002 | ||
- | | - | SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic1) | + | | rfull051 |
| rfull006 | | rfull006 | ||
| rfull007 | | rfull007 |
