community:hepsim:usage_full [2016/04/29 00:02] asc [Full detector simulation] |
community:hepsim:usage_full [2017/09/30 14:35] asc |
Line 1: | Line 1: | ||
+ | <note important> | ||
+ | http:// | ||
====== Full detector simulations | ====== Full detector simulations | ||
- | Currently, the full detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | + | Currently, the Geant4-based |
use these files for the " | use these files for the " | ||
To process SLCIO files, you will need [[http:// | To process SLCIO files, you will need [[http:// | ||
The files with full simulations are located under the " | The files with full simulations are located under the " | ||
- | Here how you can find all samples that have " | + | Here how you can find all samples that have " |
+ | The description of the detector tags is given in [[community: | ||
+ | If you need to find all files | ||
for a give tag, say rfull005, use this command: | for a give tag, say rfull005, use this command: | ||
Line 25: | Line 32: | ||
Each " | Each " | ||
- | The physics performance studies are [[fcs: | + | The physics performance studies |
+ | are [[fcs: | ||
+ | ====== Processing LCIO files ====== | ||
+ | To perform data analysis using LCIO files, use the [[https:// | ||
+ | The installation does not have external dependencies besides Java. Make sure Java7 and above is installed. | ||
+ | Then run these commands to install the package using Linux/Mac with the " | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf jas4pp.tgz | ||
+ | cd jas4pp | ||
+ | The last command optimizes Java packages for the Python language. | ||
+ | Now you are ready to run over any file with truth-level and datector-simulation files, such as LCIO and ProMC. This program can be used for: | ||
+ | * Downloading and searching HepSim data | ||
+ | * Processing ProMC files from HepSim | ||
+ | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
+ | * Data analysis (jets, physics vectors, histogram packages) | ||
+ | * Visualisation of reconstructed events using Wired4 display | ||
+ | You can find more details in [[asc: | ||
+ | The standard set of containers is available from the LCIO files posted on HepSim. Read | ||
+ | [[http:// | ||
+ | [[http:// | ||
+ | Look the Java API definition of the needed objects in [[http:// | ||
+ | BeamCalHits | ||
+ | CalorimeterHitRelations | ||
+ | EM_BARREL | ||
+ | EM_ENDCAP | ||
+ | EcalBarrelHits | ||
+ | EcalEndcapHits | ||
+ | HAD_BARREL | ||
+ | HAD_ENDCAP | ||
+ | HcalBarrelHits | ||
+ | HcalEndcapHits | ||
+ | HelicalTrackHitRelations | ||
+ | HelicalTrackHits | ||
+ | HelicalTrackMCRelations | ||
+ | LumiCalHits | ||
+ | MCParticle | ||
+ | MUON_BARREL | ||
+ | MUON_ENDCAP | ||
+ | MuonBarrelHits | ||
+ | MuonEndcapHits | ||
+ | PandoraPFOCollection | ||
+ | ReconClusters | ||
+ | SiTrackerBarrelHits | ||
+ | SiTrackerEndcapHits | ||
+ | SiTrackerForwardHits | ||
+ | SiVertexBarrelHits | ||
+ | SiVertexEndcapHits | ||
+ | StateAtECal | ||
+ | StateAtEnd | ||
+ | StateAtStart | ||
+ | TKR_RawTrackerHits | ||
+ | TKR_TrackerHits | ||
+ | Tracks | ||
+ | VXD_RawTrackerHits | ||
+ | VXD_TrackerHits | ||
+ | ====== Using C++/ROOT with LCIO ====== | ||
+ | If you need to read LCIO files in C++ code with ROOT/ | ||
+ | cd lcio-cpp; make | ||
+ | It will compile " | ||
