community:hepsim:usage_view [2016/05/02 20:50] asc |
community:hepsim:usage_view [2016/05/02 20:58] asc [Event 2] |
Line 15: | Line 15: | ||
Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | Here are a few images illustrating a single event Z'(40 TeV) → W+W- → hadrons: | ||
<fc # | <fc # | ||
Line 40: | Line 33: | ||
for this simulation | for this simulation | ||
- | You can see two high-pT jets (~20 TeV) from each W decay, and many back-splash particles: | + | You can see two high-pT jets (~20 TeV) from each W decay, and many back-splash particles. |
- | Straight lines seen on the X-Y view are from the Geant4 truth-level particles created by secondary interactions. | + | This event has many secondary interaction in the detector material. These images show |
+ | due to " | ||
A real pp (100 TeV) → Z' | A real pp (100 TeV) → Z' | ||
the presence of the protons in the initial state and pileup events (up to 1000 MinBias events). | the presence of the protons in the initial state and pileup events (up to 1000 MinBias events). | ||
Line 63: | Line 61: | ||
This is another Z'(40 TeV) → W+ W- example, where W+ decays to hadrons, and W- decays to electron and neutrino. | This is another Z'(40 TeV) → W+ W- example, where W+ decays to hadrons, and W- decays to electron and neutrino. | ||
- | This time we removed all Geant4 truth-level particles, so you can see this event exactly | + | The neutrino is not detected, but the electron |
Line 82: | Line 80: | ||
cd jas4pp | cd jas4pp | ||
- | wget http:// | + | wget http:// |
jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | jas4pp tev40mm_pythia6_zprime40tev_ww_0003_pandora.slcio | ||
- | Then press the small " | + | Then press the small " |
You will need a computer with at least 8 GB RAM. | You will need a computer with at least 8 GB RAM. | ||
