community:hepsim [2016/05/24 14:40] asc [For developers] |
community:hepsim [2016/11/06 19:11] asc [Physics and detector studies] |
Line 1: | Line 1: | ||
- | ====== HepSim manual ====== | + | ====== HepSim manual ====== |
- | HepSim is a public repository with Monte Carlo simulated events for high-energy physics (HEP) experiments. | + | [[http:// |
- | The HepSim repository was started at ANL during the US long-term planning study of the American Physical Society’s Division of Particles and Fields (Snowmass 2013) with the goal to create references to truth-level | + | The [[http:// |
+ | * BlueGene/Q supercomputer of the Argonne Leadership Computing Facility ([[hpc: | ||
+ | * [[https:// | ||
+ | * ATLAS Connect virtual cluster service (" | ||
+ | * Argonne’s Laboratory Computing Resource Center (LCRC) (" | ||
+ | * ATLAS Analysis support (ASC) cluster at HEP/ANL | ||
- | The Monte Carlo files (truth-level, fast and Gean4-based simulations) | + | The file storage is provided by: |
- | can be accessed from the [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]] link. | + | |
+ | * STASH2 storage at OSG CI Connect | ||
+ | * FAXBOX storage at ATLAS Connect | ||
+ | * MC.HEP server at ASC ANL | ||
+ | This repository was created following | ||
+ | the guidelines and principles of the | ||
+ | [[http://www.energy.gov/sites/prod/ | ||
+ | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
====== For HepSim users ====== | ====== For HepSim users ====== | ||
If you are a HepSim user, start from here. | If you are a HepSim user, start from here. | ||
Line 23: | Line 38: | ||
Here are several links to extending this Wiki for particular detector-performance topics: | Here are several links to extending this Wiki for particular detector-performance topics: | ||
- | * [[fcs: | + | * [[fcs: |
- | * [[fcs:sid:intro|SID detector studies]] - explains how to analyses data for the SiD detector (ILC) | + | * [[fcs:sid:start|SID detector studies]] - explains how to analyses data for the SiD detector (ILC) |
- | * [[fcs:cepc:intro|CEPC detector studies]] - shows some results with full simulations for CEPC | + | * [[fcs:cepc:start|CEPC detector studies]] - shows some results with full simulations for CEPC |
- | * [[fcs:eic:intro|EIC detector studies]] - shows some results with full simulations for EIC | + | * [[fcs:eic:start|EIC detector studies]] - shows some results with full simulations for EIC |
* [[vlhc: | * [[vlhc: | ||
====== For developers ====== | ====== For developers ====== | ||
If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | ||
Line 39: | Line 58: | ||
* [[community: | * [[community: | ||
- | * [[community: | + | * [[community: |
+ | * [[community: | ||
====== Public results and contributions ====== | ====== Public results and contributions ====== | ||
- | ===== How to cite ===== | + | |
- | + | ===== Public results ===== | |
+ | ===== Contributions ===== | ||
+ | ====== How to cite ====== | ||
If you use HepSim event samples, Python/ | If you use HepSim event samples, Python/ | ||
Line 52: | Line 85: | ||
- | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// | + | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments// |
<hidden Click here to display BibTeX article entry> | <hidden Click here to display BibTeX article entry> | ||
Line 70: | Line 103: | ||
- | ===== Public results ===== | ||
- | * [[https:// | ||
- | ===== Contributions ===== | ||
====== Acknowledgement ====== | ====== Acknowledgement ====== | ||
The current work is supported | The current work is supported |
